In contrast to rtems_shell_main_loop(), this new function does not
perform all sorts of initialization based on environment settings. For
example, due to the use of isatty() in rtems_shell_main_loop() it is
impossible to run an interactive shell through a socket connection.
This was requested to be executed prior to relicensing to BSD-2.
- Fix the passing of std[in/out] to child threads
- Fix deleting of managed memory in the key destructor
- Only set the key in the main loop thread
- Only allocate a shell env outside of the main loop
- Fix memory leak if the task start fails
- Remove error level from shell env, it cannot be returned this way. Add
exit_code but the API is broken so it cannot be returned.
Closes #3859
This makes the @file documentation independent of the actual file name.
Update #3707.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
