Directly use "static inline" which is available in C99 and later. This brings
the RTEMS implementation closer to standard C.
Close #3935.
Updates #3053.
Update #3706.
Use common phrases for the file brief descriptions.
Update #3706.
Adjust group identifier and names to be in line with a common pattern.
Use common phrases for the group brief descriptions.
Update #3706.
Update #3706.
This makes the @file documentation independent of the actual file name.
Update #3707.
The sbintime_t is a non-POSIX type and not visible if strict standard
options are selected.
Move implementation details from <rtems/score/timestamp.h> to
<rtems/score/timestampimpl.h>.
Update #3598.
