brains GmbH.
Directly use "static inline" which is available in C99 and later. This brings
the RTEMS implementation closer to standard C.
Close #3935.
Update #4706.
Updates #4706
Conditional expressions with inline functions are not optimized away if
optimization is disabled. Avoid such expressions to prevent dead
branches. It helps also during code review to immediately see if a loop
is used or not.
Updates #4625.
Updates #3053.
Use the new Priority_Group_order enum instead of a boolean to indicated if a
priority should be inserted as the first or last node into its priority group.
This makes the code more expressive. It is also a bit more efficient since a
branch in _Scheduler_Node_set_priority() is avoided and a simple bitwise or
operation can be used.
This fix relates to a Coverity issue (NULL_RETURNS).
Use common phrases for the file brief descriptions.
Update #3706.
Update #3706.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
