These functions do not belong to an super core service.
This function is not a super core service.
Sebastian has agreed to move this out of score. I should have
removed this patch from my tree but accidentally committed it
with another patch.
The only use was in a test.
brains GmbH.
This function may be used to burn a couple of processor cycles with
minimum impact on the system bus. It may be used in busy wait loops.
Since it is a global function, it is possible to wrap it in device
driver test code.
Updates #4625.
Updates #3053.
Update #4267.
Use common phrases for the file brief descriptions.
Update #3706.
Adjust group identifier and names to be in line with a common pattern.
Use common phrases for the group brief descriptions.
Update #3706.
Update #3904.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
