Ensure that the IDLE storage allocator did allocate a suffiently large area.
Update #3835.
Update #4524.
By default, allocate the IDLE task storage areas from the RTEMS Workspace.
This avoids having to estimate the thread-local storage size in the default
configuration.
Add the application configuration option CONFIGURE_IDLE_TASK_STORAGE_SIZE to
request a static allocation of the task storage area for IDLE tasks.
Update #3835.
Update #4524.
Add the INTERNAL_ERROR_IDLE_THREAD_CREATE_FAILED fatal error in case the
creation of an idle thread fails. This may happen due to a failing create
extension provided by the application.
The <rtems.h> header file should not unnecessarily include standard C
header files. The <string.h> and <limits.h> header includes were
removed in 2017.
Update #4662.
The warning that this fixes states that "ISO C restricts enumerator values to
range of 'int'."
Updates #4662
Updates #3053.
GCC versions prior to 6.1 used a RTEMS thread model based on
rtems_gxx_*() functions. GCC version 6.1 or later uses the
self-contained synchronization objects of Newlib <sys/lock.h> for the
RTEMS thread model.
Remove the obsolete implementation.
Close #3143.
Users have access to the fatal error source and code though the fatal error
extension. The user-specific fatal error handling should be done in statically
initialized fatal error handlers. The _Internal_errors_What_happened was
updated after the fatal error extension. In addition, there was no API to get
the information stored in _Internal_errors_What_happened. In SMP
configurations, this object could contain a mix of different fatal errors.
Remove this object to save some bytes of storage.
Add RTEMS_FATAL_SOURCE_SPURIOUS_INTERRUPT as the fatal source for
spurious interrupts. Use the interrupt vector number of the spurious
interrupt for the fatal code.
Update #3269.
Use common phrases for the file brief descriptions.
Update #3706.
Adjust group identifier and names to be in line with a common pattern.
Use common phrases for the group brief descriptions.
Update #3706.
In order to better support applications which use the new
rtems_task_construct() directive add the
CONFIGURE_INIT_TASK_CONSTURCT_STORAGE_SIZE configuration option. If
this option is specified, then the Classic API initialization task is
constructed with rtems_task_construct().
Update #4181.
Replace a runtime check with a compile time assertion. This makes the
INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL obsolete.
Update #4181.
Replace runtime checks with compile time assertions. This makes the
INTERNAL_ERROR_BAD_STACK_HOOK obsolete.
Provide RTEMS_NO_RETURN also in case RTEMS_DEBUG is defined to prevent errors
like this:
error: no return statement in function returning non-void [-Werror=return-type]
Use C11 and C++11 standard means to declare a no-return function.
Close #4122.
Add this application configuration option. This configuration option can be
used to reserve space for the dynamic linking of modules with thread-local
storage objects.
Add RTEMS_TASK_STORAGE_ALIGNMENT to define the minium alignment of a
thread-local storage size.
Update #4074.
The IO library used a POSIX key to store an optional POSIX user
environment pointer. This pulled in the POSIX keys support in every
application configuration. Add a user environment pointer to the thread
control block (TCB) instead. Applications which do not need the POSIX
user environment will just get an overhead of one pointer per thread.
Close #3882.
This function is unused.
Update #3735.
Update #3806.
Update #3706.
Update #3706
This makes the @file documentation independent of the actual file name.
Update #3707.
Allocate the per-CPU data for secondary processors directly from the
heap areas before heap initialization and not via
_Workspace_Allocate_aligned(). This avoids dependency on the workspace
allocator. It fixes also a problem on some platforms (e.g. QorIQ) where
at this early point in the system initialization the top of the RAM is
used by low-level startup code on secondary processors (boot pages).
Update #3507.
Statically allocate the objects information together with the initial
set of objects either via <rtems/confdefs.h>. Provide default object
informations with zero objects via librtemscpu.a. This greatly
simplifies the workspace size estimate. RTEMS applications which do not
use the unlimited objects option are easier to debug since all objects
reside now in statically allocated objects of the right types.
Close #3621.
The configured interrupt stack size (CONFIGURE_INTERRUPT_STACK_SIZE) is
checked against the minimum task stack size. The minium tasks task
stack size is also a configuration option
(CONFIGURE_MINIMUM_TASK_STACK_SIZE). So, this check does not really
help in case of configuration errors. In addition, the interrupt stack
is also re-used as the initialization stack in most BSPs. It is
probably better to use a stack checker to detect problems.
Update #3459.
An invalid heap usage such as a double free is usually a fatal error
since this indicates a use after free. Replace the use of printk() in
free() with a fatal error.
Update #3437.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
