The availability of a proper RTEMS_DEFINE_GLOBAL_SYMBOL() implementation
depends on __asm__() and thus __GNUC__.
Clarify documentation.
Update #4953.
brains GmbH.
There was a cyclic dependency: For RTEMS_STATIC_ANALYSIS we needed
basedefs.h in assert.h. For RTEMS_UNREACHABLE() we needed _Assert() from
assert.h in basedefs.h.
Fix this by introducing _Debug_Unreachable() in basedefs.h.
Add RTEMS_FUNCTION_NAME to basedefs.h and use it in basedefs.h and
assert.h.
Close #4900.
Two interface specification items moved.
Reflect renamed specification item.
Update #3866.
Change RTEMS_STRING() and RTEMS_XSTRING() to accept a variable number of
arguments which is stringified. This can be used for example to create
register lists for inline assembler statements.
The goal is to reduce false positive NULL_RETURNS,
PW.NORETURN_FUNCTION_DOES_RETURN, PW.SET_BUT_NOT_USED,
UNUSED_VALUE, etc. issues produced by Coverity.
Define RTEMS_STATIC_ANALYSIS if a static analysis run by Coverity is
performed.
Place the paragraphs in the same order as the directive documentation in
the RTEMS Classic API Guide.
Update #3993.
Commit 21af87199297460470578479293ec6bc8c4e04b2 accidentally removed the
RTEMS_COMPILER_UNUSED_ATTRIBUTE and added RTEMS_COMPILER_USED_ATTRIBUTE.
Change license to BSD-2-Clause according to file histories and
documentation re-licensing agreement.
Update #3899.
Update #3993.
Provide RTEMS_NO_RETURN also in case RTEMS_DEBUG is defined to prevent errors
like this:
error: no return statement in function returning non-void [-Werror=return-type]
Use C11 and C++11 standard means to declare a no-return function.
Close #4122.
Update #3959.
Update #4074.
Update #3959.
Update #4074.
This addresses compiler warnings like this:
warning: array subscript 0 is outside the bounds of an interior
zero-length array 'abc[0]' [-Wzero-length-bounds]
Update #4032.
Close #3586.
Close #3584.
Delete unused RTEMS_DECLARE_GLOBAL_SYMBOL().
Update #3799.
Update #3799.
Update #3799.
Update #3706.
Close #3734.
Update #3706
Enable the use of RTEMS_DEVOLATILE() and RTEMS_DECONST() in strict ISO C
environments.
Update #3583.
Update #3585.
Update #3584.
In standard C pointer operands are not allowed in integer constant
expressions. Avoid a static assertion based on an array typedef since
this could lead to warnings ("variably modified 'x' at file scope" and
"typedef 'x' locally defined but not used");
This implementation requires unique messages.
This avoids warnings like this:
warning: ISO C does not allow extra ';' outside of a function [-Wpedantic]
RTEMS_DECLARE_GLOBAL_SYMBOL( abc );
Update #3459.
Add RTEMS_PREDICT_TRUE() and RTEMS_PREDICT_FALSE() for static branch
prediction hints.
Close #3475.
Add RTEMS_DEFINE_GLOBAL_SYMBOL() and add RTEMS_DECLARE_GLOBAL_SYMBOL().
Update #3459.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
