path: root/cpukit/include/rtems/rtl/rtl-obj-fwd.h (follow)
* cpukit/include/rtems: Change license to BSD-2Joel Sherrill2022-03-251-3/+22
| | | | Updates #3053.
* libdl: Add object file dependencies to track referencesChris Johns2018-11-221-0/+6
| | | | | | | | | | Tracking references lets us manage when an object file can be unloaded. If an object file has references to it, it cannot be unloaded. Modules that depend on each other cannot be unloaded. Updates #3605
* libdl: Remove _t from all structures as this is reserved for the standardsChris Johns2018-04-121-4/+4
* Remove make preinstallChris Johns2018-01-251-0/+39
