brains GmbH.
Directly include <rtems/score/cpuopts.h> in header files using CPU build
options.
Move the definition of the top-level Classic API implementation group to
an implementation header file.
This type is not only used by Task Manager directives. This is a
preparation to move the rtems_scheduler_*() directives from
<rtems/rtems/tasks.h> to a new <rtems/rtems/scheduler.h>.
Rename Classic API top-level group from Classic to RTEMSImplClassic.
Use RTEMSImplClassic as a prefix for the subgroups. Change the group
names to be in line with the API group names. Use common phrases for
the group brief descriptions.
Update #3706.
Change license to BSD-2-Clause according to file histories and
documentation re-licensing agreement.
Update #3899.
Update #3993.
Move type related definition to <rtems/rtems/types.h>. The goal is to
make <rtems.h> an include only header file.
Close #3584.
This type was deprecated in RTEMS 5.1.
Close #3594.
Close #3592.
Close #3590.
Close #3588.
Replace the user MPCI configuration table with a system provided
_MPCI_Configuration.
Update #3735.
Update #3706.
Move Heap_Information_block to separate header file to hide heap
implementation details from <rtems.h>.
Update #3598.
Update #3598.
Update #3598.
Separate the definitions related to watchdog ticks from the watchdog
structures.
Update #3598.
Use a real function for rtems_clock_get_uptime_seconds().
Update #3598.
Use rtems_mode directly. This is in line with rtems_attribute and
rtems_option.
Update #3598.
Update #3598.
The rtems_thread_cpu_usage_t typedef as no corresponding API. It
violates the POSIX namespace. A user can do nothing with it.
Close #3593.
The region_information_block typedef as no corresponding API. It has no
proper namespace prefix. A user can do nothing with it.
Close #3591.
The rtems_context_fp typedef as no corresponding API. A user can do
nothing with it.
Close #3589.
The rtems_context typedef as no corresponding API. A user can do
nothing with it.
Close #3587.
Update #3584.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
