brains GmbH.
Place the paragraphs in the same order as the directive documentation in
the RTEMS Classic API Guide.
Update #3993.
Change license to BSD-2-Clause according to file histories and
documentation re-licensing agreement.
Update #3899.
Update #3993.
This patch adds the ability for termios to send SIGINTR on receipt
of VINTR and SIGQUIT for VKILL and return -1/EINTR from read() on
a termios channel. Importantly, this patch does not alter the default
behavior or force POSIX signal code in just because termios is used.
The application must explicitly enable the POSIX behavior of generating
a signal upon receipt of these characters. This is discussed in the
POSIX standard:
https://pubs.opengroup.org/onlinepubs/9699919799/basedefs/V1_chap11.html
Closes #3800.
Update #3706.
Update #3706.
This makes the @file documentation independent of the actual file name.
Update #3707.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
