path: root/cpukit/include/rtems/rtems/options.h (follow)
* Update company nameSebastian Huber2023-05-201-1/+1
| | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH.
* Add items to Doxygen groupsSebastian Huber2022-09-051-0/+2
* Improve file header comment in generated filesSebastian Huber2021-01-251-3/+7
* rtems: Generate <rtems/rtems/options.h>Sebastian Huber2020-11-121-36/+95
| | | | | | | | Change license to BSD-2-Clause according to file histories and documentation re-licensing agreement. Update #3899. Update #3993.
* doxygen: Restructured cpukit/include/rtems/rtemsAndreas Dachsberger2019-04-021-2/+2
| | | | Update #3706.
* doxygen: Reviewed cpukit/include/rtems/rtemsAndreas Dachsberger2019-04-021-4/+1
| | | | Update #3706.
* Remove explicit file names from @fileSebastian Huber2019-02-281-1/+1
| | | | | | This makes the @file documentation independent of the actual file name. Update #3707.
* Remove make preinstallChris Johns2018-01-251-0/+83
