path: root/cpukit/include/rtems/ringbuf.h (follow)
* cpukit/include: Adding file headers and licensesRyan Long2022-05-041-0/+26
| | | | | These files had no file header, copyright, or license. Based on git history, added appropriate copyright and license.
* Remove make preinstallChris Johns2018-01-251-0/+63
