path: root/cpukit/include/rtems/rfs/rtems-rfs-link.h (follow)
* cpukit/include/rtems: Change license to BSD-2Joel Sherrill2022-03-251-3/+22
| | | | Updates #3053.
* Remove make preinstallChris Johns2018-01-251-0/+124
