path: root/cpukit/include/rtems/profiling.h (follow)
* Update company nameSebastian Huber2023-05-201-1/+1
| | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH.
* cpukit/include/rtems: Change license to BSD-2Joel Sherrill2022-03-251-3/+22
| | | | Updates #3053.
* cpukit/: Scripted embedded brains header file clean upJoel Sherrill2022-03-101-6/+0
| | | | Updates #4625.
* sapi: Canonicalize @defgroup and @file commentsSebastian Huber2020-12-021-3/+3
| | | | | | | Adjust group identifier and names to be in line with a common pattern. Use common phrases for the group and file brief descriptions. Update #3706.
* doxygen: Added some subgroups to API and IOAndreas Dachsberger2019-04-041-0/+2
| | | | | | I2C library, Media Manager and Profiling Support Update #3706.
* Remove make preinstallChris Johns2018-01-251-0/+333
