path: root/cpukit/include/rtems/posix/threadsup.h (follow)
* cpukit/include/rtems/posix/*.h: Change license to BSD-2Joel Sherrill2022-02-281-3/+22
| | | | Updates #3053.
* posix: Hide POSIX_API_Control by defaultSebastian Huber2018-10-291-0/+2
| | | | Update #2514.
* Remove make preinstallChris Johns2018-01-251-0/+98
