path: root/cpukit/include/rtems/posix/semaphoreimpl.h (follow)
* Do not use RTEMS_INLINE_ROUTINESebastian Huber2022-09-191-9/+9
| | | | | | | Directly use "static inline" which is available in C99 and later. This brings the RTEMS implementation closer to standard C. Close #3935.
* cpukit/include/rtems/posix/*.h: Change license to BSD-2Joel Sherrill2022-02-281-3/+22
| | | | Updates #3053.
* score: Static Objects_Information initializationSebastian Huber2018-12-141-6/+0
| | | | | | | | | | | Statically allocate the objects information together with the initial set of objects either via <rtems/confdefs.h>. Provide default object informations with zero objects via librtemscpu.a. This greatly simplifies the workspace size estimate. RTEMS applications which do not use the unlimited objects option are easier to debug since all objects reside now in statically allocated objects of the right types. Close #3621.
* Remove RTEMS_SCORE_OBJECT_ENABLE_STRING_NAMESSebastian Huber2018-10-291-2/+4
| | | | | | | | | Enable support for string objects names unconditionally. Add const qualifier throughout. Split _Objects_Namespace_remove() into _Objects_Namespace_remove_u32() and _Objects_Namespace_remove_string() to avoid an unnecessary dependency on _Workspace_Free(). Update #2514.
* Remove make preinstallChris Johns2018-01-251-0/+143
