path: root/cpukit/include/rtems/libcsupport.h (follow)
* doxygen: Add files to groups and fix group scopesSebastian Huber2023-03-171-3/+5
* Support _REENT_THREAD_LOCAL Newlib configurationMatt Joyce2022-07-211-11/+17
| | | | | | | | | In case the Newlib _REENT_THREAD_LOCAL configuration option is enabled, the struct _reent is not defined (there is only a forward declaration in <sys/reent.h>). Instead, the usual members of struct _reent are available as dedicatd thread-local storage objects. Update #4560.
* cpukit/include/sys: Change license to BSD-2.Joel Sherrill2022-03-251-3/+22
| | | | Updates #3053.
* doxygen: Rename Internal to ImplementationSebastian Huber2020-11-231-1/+1
| | | | | | Use a top-level implementation group to gather implementation related files. The use of "Impl" is shorter and matches with the *impl.h file names.
* doxygen: Put C Library Support and POSIX in InternalAndreas Dachsberger2019-04-041-0/+2
| | | | Update #3706.
* Remove make preinstallChris Johns2018-01-251-0/+193
