path: root/cpukit/include/rtems/error.h (follow)
* cpukit/include/rtems: Add file headers and licensesRyan Long2022-05-041-0/+27
| | | | | These files had no header, copyright, or licenses. Based on git history, added appropriate copyright and license.
* Remove explicit file names from @fileSebastian Huber2019-02-281-1/+1
| | | | | | This makes the @file documentation independent of the actual file name. Update #3707.
* Remove make preinstallChris Johns2018-01-251-0/+135
