path: root/cpukit/include/rtems/diskdevs.h (follow)
* libblock: Add rtems_bdbuf_peek()Christian Mauderer2021-03-261-2/+22
| | | | | | | | Adds a peek function that allows (for example) a file system to suggest the next blocks that should be used for read ahead. This can increase the read speed of fragmented files. Update #3689
* libblock: Add RTEMS_DEPRECATEDSebastian Huber2018-08-071-114/+30
| | | | Close #3358.
* Remove make preinstallChris Johns2018-01-251-0/+511
