Fix rtems_configuration_get_interrupt_stack_size() for some code models.
The _ISR_Stack_size symbol has an arbitrary absolute address and may not
be representable in the code model used by the compiler.
Update #4953.
brains GmbH.
The application configuration options are documented in
"cpukit/doxygen/appl-config.h". Since the application configuration
option defines are also present in multiple test program sources, the
"#OPTION" references cannot be mapped to a unique definition. Add an
anchor for each option and reference it to avoid the issues with the
multiple definitions.
Update #3994.
Update #3993.
Directly include <rtems/score/cpuopts.h> in header files using CPU build
options.
Update #4524.
Add a stack allocator hook specifically for allocation of IDLE thread stacks.
This allows the user to decide if IDLE thread stacks are statically allocated
or handled by the same custom allocator mechanism as other thread stacks.
Closes #4524.
Update #4267.
Update #4269.
Place the paragraphs in the same order as the directive documentation in
the RTEMS Classic API Guide.
Update #3993.
Change license to BSD-2-Clause according to file histories and
documentation re-licensing agreement.
Update #3899.
Update #3993.
Move configuration related declarations and definitions to
<rtems/config.h>. The goal is to make <rtems.h> an include only header
file.
The CONFIGURE_DISABLE_SMP_CONFIGURATION configuration option and
rtems_configuration_is_smp_enabled() were added during the SMP support
development cycle as a workaround to fix some testsuite failures in SMP
configurations. All use cases were replaced with tests for specific
conditions. The configuration option and test macro were undocumented.
Close #3876.
Move the is SMP enabled configuration constant out of the
configuration table.
Since this was the last configuration constant in
rtems_configuration_table, remove this type.
Update #3875.
Move the processor maximum configuration constant out of the
Update #3875.
Move the unified workspace configuration constant out of the
Provide a default definition of the unified workspace constant.
Update #3875.
Move the workspace size configuration constant out of the configuration
table.
Update #3875.
Move the idle thread body configuration constant out of the
Provide a default definition of the idle thread body constant.
Update #3875.
Move the idle thread stack size configuration constant out of the
Add THREAD_IDLE_STACK_SIZE_DEFAULT and use it to provide a default
definition of the idle thread stack size constant.
Update #3875.
Move the ticks per timeslice configuration constant out of the
Add WATCHDOG_TICKS_PER_TIMESLICE_DEFAULT and use it to provide a default
definition of the watchdog ticks per timeslice constant.
Update #3875.
Move the microseconds per tick configuration constant out of the
Add WATCHDOG_MICROSECONDS_PER_TICK_DEFAULT and use it to provide a
default definition of the watchdog ticks constants.
Update #3875.
The CONFIGURE_HAS_OWN_INIT_TASK_TABLE and
CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE are the last *_HAS_OWN_*
configuration options. These two options are probably unused, see also:
* https://lists.rtems.org/pipermail/users/2019-April/033129.html
* https://lists.rtems.org/pipermail/users/2019-April/033130.html
Removing them simplifies the configuration. If there is a real user need
which shows up after the removal, we can resurrect them on demand.
Using CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE would have required the
use of the undocumented CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME and
CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE configuration options.
Update #3874.
With the removal of the CONFIGURE_HAS_OWN_INIT_TASK_TABLE configuration
option at most one Classic API user initialization task can be
configured.
Provide an RTEMS API configuration table for backward compatibility.
Update #3873.
The corresponding data structure not longer exists. This function was
not tested and documented.
Close #3871.
This allows the linker garbage collection to perform its work.
Update #3835.
Use the stack area to allocate the TLS area.
Update #3835.
Use a dedicate system initialization step to zero the memory used for
the workspace and C program heap.
This avoids dead code in case CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY is
not configured.
Replace the user MPCI configuration table with a system provided
_MPCI_Configuration.
Update #3735.
Avoid the use of the workspace and use statically allocated switch
controls for the initial extensions.
Statically allocate the objects information together with the initial
set of objects either via <rtems/confdefs.h>. Provide default object
informations with zero objects via librtemscpu.a. This greatly
simplifies the workspace size estimate. RTEMS applications which do not
use the unlimited objects option are easier to debug since all objects
reside now in statically allocated objects of the right types.
Close #3621.
Use functions instead of macros. Add missing
rtems_configuration_get_maximum_*() functions.
Update #3621.
Separate the definitions related to watchdog ticks from the watchdog
structures.
Update #3598.
Rename
* _Configuration_Interrupt_stack_area_begin in _ISR_Stack_area_begin,
* _Configuration_Interrupt_stack_area_end in _ISR_Stack_area_end, and
* _Configuration_Interrupt_stack_size in _ISR_Stack_size.
Move definitions to <rtems/score/isr.h>. The new names are considerable
shorter and in the right namespace.
Update #3459.
Update #2514.
Statically initialize the interrupt stack area
(_Configuration_Interrupt_stack_area_begin,
_Configuration_Interrupt_stack_area_end, and
_Configuration_Interrupt_stack_size) via <rtems/confdefs.h>. Place the
interrupt stack area in a special section ".rtemsstack.interrupt". Let
BSPs define the optimal placement of this section in their linker
command files (e.g. in a fast on-chip memory).
This change makes makes the CPU_HAS_SOFTWARE_INTERRUPT_STACK and
CPU_HAS_HARDWARE_INTERRUPT_STACK CPU port defines superfluous, since the
low level initialization code has all information available via global
symbols.
This change makes the CPU_ALLOCATE_INTERRUPT_STACK CPU port define
superfluous, since the interrupt stacks are allocated by confdefs.h for
all architectures. There is no need for BSP-specific linker command
file magic (except the section placement), see previous ARM linker
command file as a bad example.
Remove _CPU_Install_interrupt_stack(). Initialize the hardware
interrupt stack in _CPU_Initialize() if necessary (e.g.
m68k_install_interrupt_stack()).
The optional _CPU_Interrupt_stack_setup() is still useful to customize
the registration of the interrupt stack area in the per-CPU information.
The initialization stack can reuse the interrupt stack, since
* interrupts are disabled during the sequential system initialization,
and
* the boot_card() function does not return.
This stack resuse saves memory.
Changes per architecture:
arm:
* Mostly replace the linker symbol based configuration of stacks with
the standard <rtems/confdefs.h> configuration via
CONFIGURE_INTERRUPT_STACK_SIZE. The size of the FIQ, ABT and UND
mode stack is still defined via linker symbols. These modes are
rarely used in applications and the default values provided by the
BSP should be sufficient in most cases.
* Remove the bsp_processor_count linker symbol hack used for the SMP
support. This is possible since the interrupt stack area is now
allocated by the linker and not allocated from the heap. This makes
some configure.ac stuff obsolete. Remove the now superfluous BSP
variants altcycv_devkit_smp and realview_pbx_a9_qemu_smp.
bfin:
* Remove unused magic linker command file allocation of initialization
stack. Maybe a previous linker command file copy and paste problem?
In the start.S the initialization stack is set to a hard coded value.
lm32, m32c, mips, nios2, riscv, sh, v850:
* Remove magic linker command file allocation of initialization stack.
Reuse interrupt stack for initialization stack.
m68k:
powerpc:
* Used dedicated memory region (REGION_RTEMSSTACK) for the interrupt
stack on BSPs using the shared linkcmds.base (replacement for
REGION_RWEXTRA).
sparc:
* Remove the hard coded initialization stack. Use the interrupt stack
for the initialization stack on the boot processor. This saves
16KiB of RAM.
Update #3459.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
