Unconditionally make a CONFIGURE_TICKS_PER_TIMESLICE value less than or equal
to zero an error.
Update #4986.
Gate CONFIGURE_TICKS_PER_TIMESLICE appropriately behind
CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER.
brains GmbH.
This adds write buffer and bad block support required for JFFS2
operation on NAND devices. This also adds the minor modifications
necessary for RTEMS support in the Linux header stubs and in wbuf.c.
Memory and NOR backed applications should experience no difference in
operation since they do not expose the callbacks required for write
buffer support.
This enables the tracing of interrupt entry/exit events through an
application configuration option. The interrupt processing can be
viewed with Trace Compass using rtems-record-lttng from the RTEMS Tools.
Update #4769.
This patch changes the license to BSD-2 for all source files where the
copyright is held by Aeroflex Gaisler, Cobham Gaisler, or Gaisler Research.
Some files also includes copyright right statements from OAR and/or
embedded Brains in addition to Gaisler.
Updates #3053.
This avoids a superfluous zero initialization of the task storage area. This
reduces the system initialization time.
By default, allocate the IDLE task storage areas from the RTEMS Workspace.
This avoids having to estimate the thread-local storage size in the default
configuration.
Add the application configuration option CONFIGURE_IDLE_TASK_STORAGE_SIZE to
request a static allocation of the task storage area for IDLE tasks.
Update #3835.
Update #4524.
Use RTEMS_ZERO_LENGTH_ARRAY for flexible array member.
Update #4662.
Updates #4691.
Updates #4662
This adds the configure option CONFIGURE_POSIX_TIMERS_FACE_BEHAVIOR
which allows the application to choose whether to have the POSIX
timer_create() function follow the behavior defined by POSIX or
the FACE Technical Standard.
Updates #4691.
In case the Newlib _REENT_THREAD_LOCAL configuration option is enabled, the
struct _reent is not defined (there is only a forward declaration in
<sys/reent.h>). Instead, the usual members of struct _reent are available as
dedicatd thread-local storage objects.
Update #4560.
Do not initialize Thread_Control::libc_reent if
CONFIGURE_DISABLE_NEWLIB_REENTRANCY is defined. This helps to catch errors
with a NULL pointer exception rather than a corruption of the thread control
block.
Check all IO driver table configuration options which are used to initialize
_IO_Driver_address_table[]. Checks for the following settings were missing:
* CONFIGURE_BSP_PREREQUISITE_DRIVERS
* CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS
* CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER
* CONFIGURE_APPLICATION_EXTRA_DRIVERS
Update #3875.
Evaluate CONFIGURE_DISABLE_BSP_SETTINGS for each affected application
configuration option. This makes the code easier to review since the influence
of CONFIGURE_DISABLE_BSP_SETTINGS is locally visible in the code.
Update #3875.
This adds a confdef option allowing an application to request mapping
machine exceptions to POSIX signals. This is required for some languages
such as Ada.
Add a stack allocator hook specifically for allocation of IDLE thread stacks.
This allows the user to decide if IDLE thread stacks are statically allocated
or handled by the same custom allocator mechanism as other thread stacks.
Closes #4524.
Also updated licenses.
Closes #4400
Updates #3899
This change eliminates a system initialization dependentcy which resulted
in an application without a file system or console referencing errno being
forced to include the code to open(/dev/console), close(), atexit(),
and the unmount infrastructure.
Closes #4439.
Do not adjust the stack area begin address since this may confuse the
stack allocator and result in failed stack frees.
Account for the alignment overhead in the stack space size estimate.
Check that the stack size is in the expected interval.
Ensure that CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE meets the task
storage alignment requirement.
Use the right system initialization step for the stack allocator
initialization. Do the stack allocator initialization before the
workspace initialization so that _Memory_Allocate() can be used to get
memory for the allocator.
Expressions in static assertions must be integral constant expressions. In
integral constant expressions the use of address constant expressions is not
allowed.
In static initializers the address constant expressions are allowed. Introduce
a new macro _CONFIGURE_ASSERT_NOT_NULL() which leads to a compile time error if
the second parameter is NULL. It generates error messages like this if for
example
#define CONFIGURE_INIT_TASK_ENTRY_POINT NULL
is provided by the application:
cpukit/include/rtems/confdefs/inittask.h:51:26: error: size of unnamed array is negative
51 | ( _type ) sizeof( int[ ( _value ) != NULL ? 1 : -1 ] ) )
cpukit/include/rtems/confdefs/inittask.h:170:3: note: in expansion of macro '_CONFIGURE_ASSERT_NOT_NULL'
170 | _CONFIGURE_ASSERT_NOT_NULL(
This fix relates to CID 1470570 (PARSE_ERROR).
Update #4181.
Adjust group identifier and names to be in line with a common pattern.
Use common phrases for the group and file brief descriptions.
Update #3706.
In order to better support applications which use the new
rtems_task_construct() directive add the
CONFIGURE_INIT_TASK_CONSTURCT_STORAGE_SIZE configuration option. If
this option is specified, then the Classic API initialization task is
constructed with rtems_task_construct().
Update #4181.
Replace a runtime check with a compile time assertion. This makes the
INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL obsolete.
Update #4181.
Register a custom task stack allocator initialization handler only if
necessary.
Replace runtime checks with compile time assertions. This makes the
INTERNAL_ERROR_BAD_STACK_HOOK obsolete.
Before this patch RTEMS_Malloc_Initialize() had a fixed dependency on
_Workspace_Area. Introduce _Workspace_Malloc_initializer to have this
dependency only if CONFIGURE_UNIFIED_WORK_AREAS is defined by the
application configuration.
Merge CORE_message_queue_Buffer structure into
CORE_message_queue_Buffer_control.
Use a zero-length array for the actual message buffer. This reduces the
structure size on all targets.
Update #4007.
In contrast to rtems_task_create() this function constructs a task with
a user-provided task storage area. The new directive uses a
configuration structure instead of individual parameters.
Add RTEMS_TASK_STORAGE_SIZE() to calculate the recommended size of a
task storage area based on the task attributes and the size dedicated to
the task stack and thread-local storage. This macro may allow future
extensions without breaking the API.
Add application configuration option
CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE to adjust RTEMS
Workspace size estimate.
Update #3959.
Add this application configuration option. This configuration option can be
used to reserve space for the dynamic linking of modules with thread-local
storage objects.
Add RTEMS_TASK_STORAGE_ALIGNMENT to define the minium alignment of a
thread-local storage size.
Update #4074.
Do the stack allocator initialization and sanity check only if a
user-provided stack allocator was configured. This avoids a dependency
of _Thread_Handler_initialization() on the stack allocator.
Update #3959.
Only provide the file descriptor array if
CONFIGURE_MAXIMUM_FILE_DESCRIPTORS > 0. If someone configured
CONFIGURE_MAXIMUM_FILE_DESCRIPTORS == 0 and the appplication uses
something which requires a file descriptor, then a linker error will
show up. An alternative would be to add a zero-length array
rtems_libio_iops[ 0 ] to librtemscpu.a which would be used in this
case.
Conditionally include some header files.
Close #4061.
Update #3875.
In the previous implementation, the _ISR_Stack_area_begin and
_ISR_Stack_area_end symbols were in different sections. If they do not
have the same alignment, then the following linker directive could
separate them:
*(SORT_BY_ALIGNMENT (SORT_BY_NAME (.rtemsstack*)))
Do not use different sections and instead define _ISR_Stack_area_end
directly.
Update #3799.
This reverts commit 8e80876bdd54e36fb668eee655eec1dd588daf13
which broke several architectures.
The _ISR_Stack_area_begin and _ISR_Stack_area_end symbols are in
different sections. They must have the same alignment, otherwise the
following linker directive could separate them:
Update #3799.
Remove the following undocumented configuration options:
* CONFIGURE_FILESYSTEM_ENTRY_DOSFS
* CONFIGURE_FILESYSTEM_ENTRY_FTPFS
* CONFIGURE_FILESYSTEM_ENTRY_IMFS
* CONFIGURE_FILESYSTEM_ENTRY_JFFS2
* CONFIGURE_FILESYSTEM_ENTRY_NFS
* CONFIGURE_FILESYSTEM_ENTRY_RFS
* CONFIGURE_FILESYSTEM_ENTRY_TFTPFS
Update #3836.
This filesystem no longer exists.
Remove unused RTEMS_FILESYSTEM_TYPE_DEVFS.
Update #3894.
Do not undefine this unused BSP configuration option. This is a follow
up of commit 92b33b8d09377feb14eb5a831ce242047c58d02b.
Check for configuration errors earlier. Allow fatal dumps without the
other extensions. Add some warnings.
Update #3904.
