path: root/cpukit/include/rtems/cbs.h (follow)
* Do not use RTEMS_INLINE_ROUTINESebastian Huber2022-09-191-12/+12
| | | | | | | Directly use "static inline" which is available in C99 and later. This brings the RTEMS implementation closer to standard C. Close #3935.
* cpukit/include/rtems/cbs.h: Change license to BSD-2Joel Sherrill2022-04-011-3/+22
| | | | | | Permission received from Petr Benes Updates #3053.
* Remove make preinstallChris Johns2018-01-251-0/+244
