path: root/cpukit/include/rtems/bspcmdline.h (follow)
* cpukit/include/sys: Change license to BSD-2.Joel Sherrill2022-03-251-3/+22
| | | | Updates #3053.
* doxygen: Split up "libmisc" subgroups and removed libmiscAndreas Dachsberger2019-04-041-1/+3
| | | | Update #3706.
* doxygen: Added libmisc group and libmisc mouse groupAndreas Dachsberger2019-04-041-3/+2
| | | | | | | | Update #3706. @ingroup for these groups already existed, but no @defgroup Further restructuring necessary
* Remove explicit file names from @fileSebastian Huber2019-02-281-1/+1
| | | | | | This makes the @file documentation independent of the actual file name. Update #3707.
* Remove make preinstallChris Johns2018-01-251-0/+131
