path: root/cpukit/include/pci/cfg_read.h (follow)
* cpukit: Change license to BSD-2 for files with Gaisler copyrightDaniel Cederman2022-11-141-3/+22
| | | | | | | | | This patch changes the license to BSD-2 for all source files where the copyright is held by Aeroflex Gaisler, Cobham Gaisler, or Gaisler Research. Some files also includes copyright right statements from OAR and/or embedded Brains in addition to Gaisler. Updates #3053.
* cpukit/include; Remove SPDX from Gaisler files NOT changed to BSD-2Joel Sherrill2022-04-021-2/+0
* cpukit/include/pci: Manual header file clean upJoel Sherrill2022-03-251-2/+10
* Remove make preinstallChris Johns2018-01-251-0/+21
