The kernel space parts of standard system header files were protected
against misuse by a preprocessor error directive. This approach does
not work well with tools such as Doxygen. Provide the kernel space
items only if the required defines are present.
Check if given address/FIB exists locally.
Reviewed by: melifaro
Differential revision: https://reviews.freebsd.org/D32913
Move the kernel space content of some Newlib provided header files to
RTEMS and libbsd. This allows to use the Newlib provided header files
with different FreeBSD baselines.
Update #3472.
