path: root/cpukit/include/drvmgr (follow)
* cpukit: Change license to BSD-2 for files with Gaisler copyrightDaniel Cederman2022-11-144-12/+88
| | | | | | | | | This patch changes the license to BSD-2 for all source files where the copyright is held by Aeroflex Gaisler, Cobham Gaisler, or Gaisler Research. Some files also includes copyright right statements from OAR and/or embedded Brains in addition to Gaisler. Updates #3053.
* Do not use RTEMS_INLINE_ROUTINESebastian Huber2022-09-191-2/+2
| | | | | | | Directly use "static inline" which is available in C99 and later. This brings the RTEMS implementation closer to standard C. Close #3935.
* cpukit/include; Remove SPDX from Gaisler files NOT changed to BSD-2Joel Sherrill2022-04-024-8/+0
* cpukit/include/drvmgr: Manual header file clean upJoel Sherrill2022-03-254-7/+35
* drvmgr: Improve LP64 compatibilitySebastian Huber2018-12-271-2/+2
* leon, spwtdp: Initial driver commitJavier Jalle2018-10-091-0/+4
* drvmgr: Remove bsp_driver_level_hook()Sebastian Huber2018-04-201-6/+0
| | | | | | Use RTEMS_SYSINIT_ITEM() instead. Update #2408.
* Remove make preinstallChris Johns2018-01-254-0/+1485
