path: root/cpukit/include/dev/serial/sc16is752.h (follow)
* Update company nameSebastian Huber2023-05-201-1/+1
| | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH.
* cpukit/include/dev: Change license to BSD-2Joel Sherrill2022-03-251-3/+22
| | | | Updates #3053.
* cpukit/: Scripted embedded brains header file clean upJoel Sherrill2022-03-101-6/+0
| | | | Updates #4625.
* dev/sc16is752: Fix declarationSebastian Huber2020-08-051-1/+1
* dev/sc16is752: Add set/get EFCR IO controlsSebastian Huber2019-06-141-0/+10
* dev/sc16is752: Add RS485 mode variantsSebastian Huber2019-06-141-1/+12
* dev/sc16is752: Add GPIO access via ioctl.Christian Mauderer2018-02-121-0/+45
* Remove make preinstallChris Johns2018-01-251-0/+262
