* pppd/Makefile.am: Don't include @RTEMS_BSP@.cfg.
Eliminate *_O_FILES.
* rtems_servers/Makefile.am: Ditto.
* rtems_webserver/Makefile.am: Ditto.
* rtems_telnetd/Makefile.am: Ditto.
* pppd/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtems_servers/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtems_telnetd/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtems_webserver/Makefile.am: Use .$(OBJEXT) instead of .o.
* arpa/Makefile.am: Remove AUTOMAKE_OPTIONS.
* kern/Makefile.am: Remove AUTOMAKE_OPTIONS.
* lib/Makefile.am: Remove AUTOMAKE_OPTIONS.
* libc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* machine/Makefile.am: Remove AUTOMAKE_OPTIONS.
* net/Makefile.am: Remove AUTOMAKE_OPTIONS.
* netinet/Makefile.am: Remove AUTOMAKE_OPTIONS.
* nfs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* pppd/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems_servers/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems_telnetd/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems_webserver/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sys/Makefile.am: Remove AUTOMAKE_OPTIONS.
* vm/Makefile.am: Remove AUTOMAKE_OPTIONS.
* machine/Makefile.am: Use 'PREINSTALL_FILES ='.
* net/Makefile.am: Use 'PREINSTALL_FILES ='.
* netinet/Makefile.am: Use 'PREINSTALL_FILES ='.
* vm/Makefile.am: Use 'PREINSTALL_FILES ='.
* pppd/Makefile.am: Use 'PREINSTALL_FILES ='.
* sys/Makefile.am: Use 'PREINSTALL_FILES ='.
* rtems_servers/Makefile.am: Use 'PREINSTALL_FILES ='.
* arpa/Makefile.am: Use 'PREINSTALL_FILES ='.
* nfs/Makefile.am: Use 'PREINSTALL_FILES ='.
* rtems_webserver/Makefile.am: Use 'PREINSTALL_FILES ='.
* rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* rtems_telnetd/Makefile.am: Use 'PREINSTALL_FILES ='.
* Makefile.am, arpa/Makefile.am, machine/Makefile.am, net/Makefile.am,
netinet/Makefile.am, nfs/Makefile.am, rtems/Makefile.am,
rtems_servers/Makefile.am, rtems_webserver/Makefile.am,
sys/Makefile.am, vm/Makefile.am:
* Makefile.am: Add handling of *.h files.
* configure.in: Remove include/Makefile.
* rtems_webserver/Makefile.am, rtems_webserver/base64.c,
rtems_webserver/base64.c: Renamed base64.c to wbase64.c.
* rtems_webserver/sock.c: Added file missed in merger.
* kern/Makefile.am, lib/Makefile.am, libc/Makefile.am,
net/Makefile.am, netinet/Makefile.am, nfs/Makefile.am,
pppd/Makefile.am, rtems/Makefile.am, rtems_servers/Makefile.am,
rtems_webserver/Makefile.am, wrapup/Makefile.am: Include compile.am
* Merged version 2.1 of GoAhead webserver. This update
was submitted by Antti P Miettinen <antti.p.miettinen@nokia.com>.
* NOTES, base64.c, ejIntrn.h, emfdb.c, emfdb.h, md5.h, md5c.c,
um.c, um.h: New files.
* wbase64.c: Removed.
* Makefile.am, asp.c, balloc.c, default.c, ej.h, ejlex.c, ejparse.c,
form.c, h.c, handler.c, mime.c, misc.c, ringq.c, rom.c, security.c,
socket.c, sym.c, uemf.c, uemf.h, url.c, value.c, webcomp.c, webmain.c,
webpage.c, webrom.c, webs.c, webs.h, websuemf.c, wsIntrn.h: Modified.
./bootstrap
