brains GmbH.
Updates #4625.
This allows a SPI driver to add a hardware specific ioctl.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #2843.
Added a mmap file handler to struct _rtems_filesystem_file_handlers_r.
Updated each file handler object to support the default mmap handler.
Updated mmap() to call the mmap handler for MAP_SHARED.
Added a mmap file handler for shm
Added support for MAP_ANON in mmap().
Updates #2859
User API is compatible to Linux userspace API. New test libtests/spi01.
Update #2776.
