* | Update company name | Sebastian Huber | 2023-05-20 | 1 | -1/+1 |
| | | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | ||||
* | cpukit/: Scripted embedded brains header file clean up | Joel Sherrill | 2022-03-10 | 1 | -6/+0 |
| | | | | Updates #4625. | ||||
* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -2/+2 |
* | i2c: Fix EEPROM driver program timeout handling | Sebastian Huber | 2017-10-02 | 1 | -4/+13 |
| | | | | | | | | The RTEMS_MILLISECONDS_TO_TICKS() macro doesn't round up. Do not use it to calculate the program timeout in ticks. Check program done condition after the timeout check to account for pre-emptions. Update #3162. | ||||
* | i2c: Send MSB of address first for EEPROMs | Sebastian Huber | 2017-10-02 | 1 | -12/+21 |
| | | | | Update #3161. | ||||
* | i2c: Avoid undefined right shift operation | Sebastian Huber | 2014-11-26 | 1 | -5/+8 |
* | Add generic EEPROM I2C device driver | Sebastian Huber | 2014-11-20 | 1 | -0/+260 |
