path: root/cpukit/Makefile.am (follow)
* 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-141-2/+0
| | | | * Makefile.am: Unconditional build libblock.
* 2009-10-08 Chris Johns <chrisj@rtems.org>Chris Johns2009-10-081-2/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Makefile.am, preinstall.am: Added statvfs.h. * libcsupport/Makefile.am: Add statvfs.c. * libcsupport/include/sys/statvfs.h, libcsupport/src/statvfs.c: New. * libcsupport/include/rtems/libio.h: Add a file system handler for the statvfs call. * libfs/src/devfs/devfs_init.c, libfs/src/dosfs/msdos_init.c, libfs/src/imfs/imfs_init.c, libfs/src/nfsclient/src/nfs.c: Set the statvfs handler to NULL. * include/rtems/fs.h: Add a second node access field for the RFS file system to hold a directory offset while the existing field holds the inode number. This save a rescan of the directory when working with directories. * libblock/include/rtems/bdbuf.h: Added references and user fields to the buffer descriptor. * libblock/src/bdbuf.c: Added dynamic buffer support for different block sizes. Fixed a number of bugs. * libblock/src/blkdev.c: Release the disk device on an error. * libblock/src/diskdevs.c: Set the block size to the media block size during initialisation of the disk device. * libblock/src/flashdisk.c, libblock/src/nvdisk.c, libblock/src/ramdisk.c: Updated the drivers to handle variable block sizes. * libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h: Release any buffers when an error occurs. The FAT buffer layer hangs onto a single buffer while mounted. This should be fixed. * sapi/inline/rtems/chain.inl: Added rtems_chain_set_off_chain, rtems_chain_is_node_off_chain, and rtems_chain_previous. * score/inline/rtems/score/chain.inl: Added _Chain_Set_off_chain, and _Chain_Is_node_off_chain. * libmisc/shell/main_ln.c, libmisc/shell/main_mknod.c, libmisc/shell/mknod-pack_dev.c, libmisc/shell/mknod-pack_dev.h: New shell commands. * libmisc/Makefile.am, libmisc/shell/shellconfig.h: Added ln and mknod commands. * libmisc/shell/hexdump-display.c: Fixed the reopen bug which showed up as a free with a bad pointer. * libmisc/shell/main_mount.c: List the user adding file system when listing the available file systems to mount. * libmisc/shell/utils-cp.c: Remove the fixed static copy buffer and use a large dynamic buffer. * score/inline/rtems/score/address.inl, score/src/coremsgsubmit.c, score/src/objectallocate.c, score/src/objectfree.c: Remove warnings.
* 2009-08-21 Roxana Leontie <roxana.leontie@gmail.com>Joel Sherrill2009-08-211-2/+2
| | | | | | | | * Makefile.am, preinstall.am, libmisc/Makefile.am: Changed the name of mw-fb directory into fb. Relocated files. * libmisc/fb/fb.h, libmisc/fb/mw_uid.c, libmisc/fb/mw_uid.h: New files. * libmisc/mw-fb/fb.h, libmisc/mw-fb/mw_uid.c, libmisc/mw-fb/mw_uid.h: Removed.
* 2009-08-05 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-08-051-0/+3
| | | | | | | * Makefile.am, preinstall.am, libmisc/Makefile.am, wrapup/Makefile.am: Add new BSP Boot Command Line helper routines. Recently boot_card() has grown the ability to have a command line string pointer. These routines provide an interface to that string.
* 2009-08-03 Roxana Leontie <roxana.leontie@gmail.com>Joel Sherrill2009-08-031-1/+1
| | | | | | * Makefile.am, preinstall.am, libmisc/Makefile.am: changed the references to mw_fb.h into fb.h * libmisc/mw-fb/mw_fb.h: renamed fb.h
* 2009-07-22 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-07-221-0/+3
| | | | | | | | | | | | | | | | | * Makefile.am, preinstall.am, libmisc/Makefile.am, wrapup/Makefile.am: Add the stringto family of string to number converters. These are error checking wrappers for the strtoXXX methods and do their best to return false if the conversion failed. The error checking required for this is tedious and error prone. Hence better to have in a family of helper routines. * libmisc/stringto/stringto.h, libmisc/stringto/stringto_template.h, libmisc/stringto/stringtodouble.c, libmisc/stringto/stringtofloat.c, libmisc/stringto/stringtoint.c, libmisc/stringto/stringtolong.c, libmisc/stringto/stringtolonglong.c, libmisc/stringto/stringtounsignedchar.c, libmisc/stringto/stringtounsignedint.c, libmisc/stringto/stringtounsignedlong.c, libmisc/stringto/stringtounsignedlonglong.c: New files.
* UpdateThomas Doerfler2009-05-051-1/+5
* removed obsolete references to login.hThomas Doerfler2009-04-141-2/+1
* 2009-03-27 Sebastian Huber <sebastian.huber@embedded-brains.de>Joel Sherrill2009-03-271-1/+2
| | | | | | | | | | | | * Makefile.am, preinstall.am, libmisc/Makefile.am, libmisc/shell/shell.c, libmisc/shell/shell.h, telnetd/check_passwd.c, telnetd/telnetd.c, telnetd/telnetd.h: Generalized login check. * libmisc/shell/login.h, libmisc/shell/login_check.c, libmisc/shell/login_prompt.c: New files. * libmisc/stackchk/check.c: Changed format for blown stack message. * libcsupport/src/libio_sockets.c: Removed superfluous cast. * libnetworking/rtems/ftpfs.h: Documentation.
* Add include/sys/priority.h.Ralf Corsepius2009-02-201-0/+1
* Remove tar.h.Ralf Corsepius2009-02-061-2/+0
* Install libnetworking/sys/uio.h if building for NEWLIB.Ralf Corsepius2009-01-051-0/+2
* Remove include/rtems/stdint.h.Ralf Corsepius2008-12-171-1/+1
* 2008-10-14 Wei Shen <cquark@gmail.com>Joel Sherrill2008-10-141-0/+3
| | | | | | | | | | | | * Makefile.am, preinstall.am, libcsupport/src/mknod.c, libcsupport/src/open.c, libcsupport/src/pipe.c, libfs/Makefile.am, libfs/preinstall.am, libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_creat.c, libfs/src/imfs/imfs_debug.c, libfs/src/imfs/imfs_eval.c, libfs/src/imfs/imfs_initsupp.c, libfs/src/imfs/imfs_mknod.c, libfs/src/imfs/imfs_stat.c, libfs/src/imfs/memfile.c: Initial commit of POSIX pipe support. * libfs/src/imfs/imfs_fifo.c, libfs/src/pipe/fifo.c, libfs/src/pipe/pipe.c, libfs/src/pipe/pipe.h: New files.
* 2008-09-17 Miao Yan <yanmiaobest@gmail.com>Joel Sherrill2008-09-171-0/+3
| | | | | | | | | | | | | | | | | | | | | | | * Makefile.am, preinstall.am, libcsupport/Makefile.am, libcsupport/include/rtems/libcsupport.h, libcsupport/include/rtems/libio.h, libcsupport/src/base_fs.c, libcsupport/src/libio_init.c, libcsupport/src/newlibc_exit.c, libcsupport/src/newlibc_init.c, libcsupport/src/sync.c, libfs/Makefile.am, libfs/src/imfs/deviceio.c, sapi/include/confdefs.h: Merge GSOC project code to add simple device only filesystem (devfs), optionally completely drop out filesystem, and to clean up disabling newlib reentrancy support. This dropped 17K from the minimum.exe for sparc/sis and arm/rtl22xx_t now has a 15K code space. * libcsupport/src/__usrenv.c, libcsupport/src/newlibc_reent.c, libfs/src/devfs/devclose.c, libfs/src/devfs/devfs.h, libfs/src/devfs/devfs_eval.c, libfs/src/devfs/devfs_init.c, libfs/src/devfs/devfs_mknod.c, libfs/src/devfs/devfs_node_type.c, libfs/src/devfs/devfs_show.c, libfs/src/devfs/devioctl.c, libfs/src/devfs/devopen.c, libfs/src/devfs/devread.c, libfs/src/devfs/devstat.c, libfs/src/devfs/devwrite.c, libfs/src/imfs/deviceerrno.c: New files. * libcsupport/src/newlibc.c: Removed.
* added BSP to m68kThomas Doerfler2008-07-111-1/+4
| | | | adapted PPC exception code
* 2008-05-01 Chris Johns <chrisj@rtems.org>Chris Johns2008-05-011-0/+1
| | | | | | | | | * libblock/include/rtems/nvdisk-sram.h, libblock/include/rtems/nvdisk.h, libblock/src/nvdisk-sram.c, libblock/src/nvdisk.c: New. A Non-volatile memory disk drive. * Makefile.am, preinstall.am, libblock/Makefile.am: Updated for the NV disk driver.
* 2007-12-12 Chris Johns <chrisj@rtems.org>Chris Johns2007-12-141-1/+1
| | | | | | | | * Makefile.am, preinstall.am: Added libblock/include/rtems/flashdisk.h to the installed header list. * libblock/Makefile.am: Add flashdisk.c to the files to build. * libblock/include/rtems/flashdisk.h, libblock/src/flashdisk.c: New.
* 2007-12-12 Chris Johns <chrisj@rtems.org>Chris Johns2007-12-121-1/+1
| | | | | | | | | * Makefile.am: Added libmisc/shell/shellconfig.h to the installed header list. * libmisc/shell/shell_cmdset.c: Let the Initial command add occur in any order rather than before any commands have been added. Also made the command's strings be copies rather than references. * sapi/src/ioregisterdriver.c: Return the I/O initialise calls result.
* 2007-12-11 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2007-12-121-0/+1
| | | | | | | | | | | | * Makefile.am, configure.ac, posix/Makefile.am, wrapup/Makefile.am: Move Ada support code that is untestable from the Standard RTEMS Test Suite into its own directory. All code in score, posix, rtems, and sapi should be testable by the Standard RTEMS Test Suites. It was buried under POSIX before so this should be a clearer location anyway. * libgnat/.cvsignore, libgnat/Makefile.am, libgnat/ada_intrsupp.c, libgnat/adasupp.c: New files. * posix/src/ada_intrsupp.c, posix/src/adasupp.c: Removed.
* 2007-06-12 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-06-121-0/+1
| | | | * configure.ac, Makefile.am: Add libmd.
* Add shttpd.Ralf Corsepius2007-06-111-0/+1
* 2007-05-15 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2007-05-151-3/+0
| | | | | | | | | | | | | | | | | | | | | | * Makefile.am, preinstall.am, libmisc/Makefile.am, rtems/Makefile.am, rtems/include/rtems.h, rtems/include/rtems/rtems/ratemon.h, rtems/inline/rtems/rtems/ratemon.inl, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemontimeout.c, score/Makefile.am, score/include/rtems/score/object.h, score/src/threadhandler.c, wrapup/Makefile.am: Integrate Rate Monotonic Statistics and Period Usage into Rate Monotonic Manager. Added the following directives: rtems_rate_monotonic_get_statistics, rtems_rate_monotonic_reset_statistics, rtems_rate_montonic_reset_all_statistics, rtems_rate_montonic_report_statistics, and rtems_object_get_name. Obsoleted the rtems/rtmonuse.h file as a public interface. * rtems/src/ratemongetstatistics.c, rtems/src/ratemonreportstatistics.c, rtems/src/ratemonresetall.c, rtems/src/ratemonresetstatistics.c, rtems/src/rtemsobjectgetname.c, score/src/objectgetnameasstring.c: New files. * libmisc/rtmonuse/rtmonuse.c, libmisc/rtmonuse/rtmonuse.h: Removed.
* 2007-05-10 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-05-101-2/+1
| | | | * Makefile.am: Remove libcsupport/include/sys/cdefs.h.
* Reflect introduction of include/rtems/bsd/sys/cdefs.h.Ralf Corsepius2007-05-101-0/+1
* 2007-05-10 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-05-101-0/+3
| | | | * Makefile.am: Reflect addition of include/rtems/bsd/sys/queue.h.
* 2007-05-09 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-05-091-0/+2
| | | | * Makefile.am: Add include/rtems/endian.h.
* Abandon DEPRECATED_TYPES.Ralf Corsepius2006-12-131-30/+0
* 2006-11-20 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-11-201-2/+0
| | | | * Makefile.am: Remove ampolish3.
* Replace AM_CONDITIONAL(HAS_NETWORKING) with AM_CONDITIONAL(LIBNETWORKING).Ralf Corsepius2006-11-181-3/+3
* Introduce AM_CONDITIONAL(LIBITRON).Ralf Corsepius2006-11-171-1/+1
| | | | Remove AM_CONDITIONAL(HAS_ITRON).
* 2006-11-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-11-171-2/+2
| | | | | * configure.ac, Makefile.am, libfs/Makefile.am: Introduce AM_CONDITIONAL(LIBDOSFS).
* Remove RTEMS_PROVIDES_STDINT_H, RTEMS_PROVIDES_INTTYPES_H.Ralf Corsepius2006-11-121-6/+0
* 2006-06-28 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-06-291-0/+2
| | | | * Makefile.am: Add ampolish3.
* 2006-01-13 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2006-01-131-10/+0
| | | | | * Makefile.am: Remove doxygen support having accidentially slipped into, though yesterday's patch.
* Remove all-local.Ralf Corsepius2006-01-121-2/+0
* CleanupsRalf Corsepius2006-01-121-5/+11
* 2005-11-02 straumanatslacdotstanford.eduTill Straumann2005-11-031-0/+4
| | | | | | | | * libi2c/Makefile.am, libi2c/Makefile.in, libi2c/libi2c.c, libi2c/libi2c.h: New files. * Makefile.am, configure.ac, preinstall.am, wrapup/Makefile.am: added a simple API/library for i2c devices and drivers for i2c 2-byte eeproms and a ds1621 temperature sensor; API is documented in libi2c.h
* Add zlib.Ralf Corsepius2005-10-301-0/+2
* Cosmetics.Ralf Corsepius2005-10-271-2/+4
* Add pppd.Ralf Corsepius2005-10-261-0/+1
* 2005-10-26 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-10-261-0/+2
| | | | | * backward/rtemspppd.h, backward/rtemsdialer.h: New. * Makefile.am: Add backward/rtemspppd.h, backward/rtemsdialer.h.
* Add telnetd.Ralf Corsepius2005-10-251-0/+1
* 2005-08-05 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-08-051-0/+2
| | | | | * Makefile.am: Add libnetworking/memory.h * libnetworking/Makefile.am: Remove memory.h
* Remove ada.Ralf Corsepius2005-05-231-1/+1
* 2005-05-17 Jennifer Averett <jennifer.averett@oarcorp.com>Jennifer Averett2005-05-171-0/+3
| | | | | * Makefile.am, preinstall.am: Added a common irq.h * include/rtems/irq.h: New file.
* Add rtems_bsdnet_HEADERS.Ralf Corsepius2005-05-091-0/+7
* 2005-03-04 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-03-041-0/+4
| | | | | | * configure.ac: Check for newlib with stdint.h/inttypes.h. * Makefile.am: Conditionally use external stdint.h/inttypes.h for newlib.
* Split preinstallation rules in to separate files (preinstall.am).Ralf Corsepius2005-02-081-305/+13
* 2005-02-08 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-02-081-0/+58
| | | | | | | * configure.ac: Add new header guard to cpuopts.h. * Makefile.am: Add libfs, libblock, ftpd header install rules. * libfs/Makefile.am, libblock/Makefile.am, ftpd/Makefile.am: Remove header install rules.
