* | contrib: Remove. | Joel Sherrill | 2013-03-12 | 1 | -20/+0 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -3/+0 |
* | 2007-08-20 Chris Johns <chisj@rtems.org> | Chris Johns | 2007-08-20 | 1 | -0/+23 |
* filewrite.nsi, getparameters.nsi, instance-check.nsi, mingw-path.nsi, sm-dummy.nsi, strslash.nsi, strstr.nsi, options.nsi: Added the shared between the 2 installer scripts. * msys-path.nsi: Fixed the last LF bug. * rtems-autotools.nsi, rtems-tools.nsi: Fixed the instance check, added a start menu, remove pages from target installers. * rtems.ini: Fixed the URL links. Added support link. * rtems_logo.bmp: Trimmed a little more to get a better image. * ba-wrap.sh: Stop on a error. * build-exes.sh: Use the option parameter variables. Change the order the section appear in the installer. |
