* console/fb_vga.c, console/kd.h: Convert C++ style comments to C
style.
* include/arm_mode_bits.h: Convert C++ style comments to C style.
* at91rm9200/include/at91rm9200.h,
at91rm9200/include/at91rm9200_dbgu.h,
at91rm9200/include/at91rm9200_emac.h,
at91rm9200/include/at91rm9200_gpio.h,
at91rm9200/include/at91rm9200_mem.h,
at91rm9200/include/at91rm9200_pmc.h, s3c2400/include/s3c2400.h:
memory autodetection code can easily fail (boards with
'reserved' regions - I experienced a hard lockup on a
dell precision 490 when writing past the bios-reported
memory size) I added code that a) tries to save
and use multiboot info, if present b) allows applications
to override/set memory size via a weak alias.
* libchip/network/greth.c, libchip/network/open_eth.c,
libchip/network/smc91111.c, libchip/network/sonic.c: Fix error
introduced by warning removal.
libchip/network/smc91111.c: Remove warnings and correct prototype
added earlier today.
* libchip/network/cs8900.c, libchip/network/greth.c,
libchip/network/i82586.c, libchip/network/open_eth.c,
libchip/network/sonic.c: Remove warnings -- use uintptr_t, properly
sized integers, and inttypes.h printf helpers.
* startup/bspstart.c: Revert patch adding new exception support code to
an old exception BSP.
* startup/bspstart.c: Add basic _BSP_Fatal_error.
to VME CSR space if the BSP defines _VME_CSR_ON_PCI
* Makefile.am, preinstall.am, startup/linkcmds, startup/linkcmds.brs5l,
startup/linkcmds.pm520: Add support for missing .rela sections.
Install linkcmds.
fixed bug in mscan
'frame' argument to C_dispatch_irq_handler(). It's
really a BSP_Exception_frame*, not a CPU_Interrupt_frame*.
* ChangeLog: New file.
* .cvsignore: New file.
* startup/linkcmds: Clean up a bit after adding missing .rela sections.
* clock/clock.c: New file.
* aclocal/rtems-cpu-subdirs.m4: New port to Altera NIOS II.
* TOOL_TARGETS: New port to Altera NIOS II.
* nios2/Makefile.am, nios2/configure.ac, nios2/preinstall.am,
nios2/shared/cache/cache.c, nios2/shared/cache/cache_.h,
nios2/shared/misc/memcpy.c: New files.
* ChangeLog, Makefile.am, README, acinclude.m4, configure.ac,
nios2_iss/ChangeLog, nios2_iss/Makefile.am, nios2_iss/bsp_specs,
nios2_iss/configure.ac, nios2_iss/nios2_iss.ptf,
nios2_iss/nios2_iss.sh, nios2_iss/times, nios2_iss/console/console.c,
nios2_iss/include/bsp.h, nios2_iss/include/bspopts.h.in,
nios2_iss/include/coverhd.h, nios2_iss/include/tm27.h,
nios2_iss/shmsupp/addrconv.c, nios2_iss/shmsupp/getcfg.c,
nios2_iss/shmsupp/lock.c, nios2_iss/shmsupp/mpisr.c,
nios2_iss/start/crtnn.s, nios2_iss/start/start.S,
nios2_iss/startup/bspclean.c, nios2_iss/startup/bspstart.c,
nios2_iss/startup/linkcmds, nios2_iss/startup/main.c,
nios2_iss/startup/setvec.c, nios2_iss/timer/timer.c: New files.
* preinstall.am: Install spacewire.h
* clock/ckinit.c, include/leon.h, timer/timer.c, amba/amba.c
fixed up merge from 4.6.6. Correct references to
LEON3_IrqCtrl_Regs_Map.mask[x] and LEON3_Timer_Regs_Map.timer[x].
-1 on failure, not just non-zero status. I found that
some driver(s) [e.g. dec21140] explicitely check for -1.
Checked inline assembly code; added 'm' operands and
paranoia 'memory' clobbers. Also, made sure that no
pure input operands are modified by the asm.
(gcc-4.1.1 warns that uint32_t and unsigned int are different).
assembly code; added 'memory' clobbers and made sure
any registers modified by the 'asm' appear in the output
operands.
* amba/amba.c, clock/ckinit.c, include/amba.h, timer/timer.c: Search
for the Timer Register when initializing the amba rather than before
each potential use.
* libchip/shmdr/shm_driver.h: Merge sparc shm driver mods from 4.6.
* Makefile.am, include/leon.h: Try to merge rest of 4.6 BSP changes.
* include/spacewire.h: New file.
* Makefile.am: Merge SHM support from 4.6 branch.
* shmsupp/README, shmsupp/addrconv.c, shmsupp/getcfg.c, shmsupp/lock.c,
shmsupp/mpisr.c: New files.
* clock/ckinit.c: Actually call the routine to find the LEON3 time.
* leon_greth/.cvsignore, leon_greth/leon_greth.c: New files.
Missed adding in previous commit of merge.
* clock/ckinit.c, timer/timer.c: Make sure LEON3_Timer_Regs is
initialized for the timer driver.
* libchip/Makefile.am, libchip/preinstall.am: Merge SPARC updates from
4.6 branch. Original modifications by Gaisler Enterprises.
* libchip/network/greth.c, libchip/network/greth.h: New files.
* ChangeLog, Makefile.am, clock/ckinit.c, include/amba.h,
include/bsp.h: Merge SPARC updates from 4.6 branch. Original
* Makefile.am: Add ampolish3.
* ampolish3: New.
* aclocal/rtems-ampolish.m4: Reflect using in-sourcetree ampolish3.
