* shared/bootloader/head.S: disable USE_PPCBUG under qemu.
* shared/startup/bspstart.c: Select console *before* doing
any potential printk() (e.g., panic).
* shared/startup/ppc_idle.c: Need to enable HID0[NAP] on
a 7400/7455/7457 for MSR[POW] to have an effect.
* shared/irq/apic.h, shared/smp/smp-imps.c, shared/smp/smp-imps.h:
Reformat to be more compliant with RTEMS style.
* motorola_powerpc/make/custom/qemuprep-altivec.cfg,
motorola_powerpc/Makefile.am: added altivec-enabled variant.
* motorola_powerpc/Makefile.am,
motorola_powerpc/configure.ac, motorola_powerpc/preinstall.am,
motorola_powerpc/include/bsp.h, motorola_powerpc/make/custom/qemuprep.cfg,
motorola_powerpc/qemu_fakerom/Makefile.am,
motorola_powerpc/qemu_fakerom/.cvsignore:
Added 'qemuprep' BSP variant.
* shared/bootloader/mm.c, shared/bootloader/pci.c,
shared/bootloader/qemu_fakeres.c, shared/bootloader/qemu_fakerom.S,
shared/irq/irq.h, shared/motorola/motorola.c, shared/residual/residual.h,
shared/startup/bspstart.c,
* shared/bootloader/misc.c: Copy residual data
_before_ decompressing the kernel since the firmware
may have stored it in an area that is overwritten
by decompress_kernel().
* shared/startup/ppc_idle.c: added an 'idle task' body
which switches the CPU into power-save mode. IIRC, this
cannot be used on real hardware due to errata :-( but
it still saves valuable host-CPU cycles when used by
the qemuprep BSP.
* shared/irq/init_irq.c, shared/irq/openpic_i8259_irq.c,
shared/pci/detect_raven_bridge.c: conditionally compile
ISA and PCI-interrupt related stuff only if BSP defines
BSP_ISA_IRQ_NUMBER > 0 and/or BSP_PCI_IRQ_NUMBER > 0,
respectively.
* shared/irq/apic.h, shared/smp/smp-imps.c, shared/smp/smp-imps.h: Per
email with Erich Boleyn, change license to BSD style.
* shared/irq/irq.c, shared/irq/irq.h, shared/irq/irq_init.c: Add
initial support for APIC.
* shared/irq/apic.h, shared/smp/README, shared/smp/smp-imps.c,
shared/smp/smp-imps.h: New files.
* start/start.S: Moved enable_sse into a subroutine that may be called
from other cores on an SMP system.
PR 1833/bsps
* ne2000/ne2000.c: Addition of multicast support disabled broadcast
reception. Patch also includes support to work on big endian CPUs.
* make/custom/pcp4.cfg: New file.
PR 1832/libcpu
* at91rm9200/irq/irq.c: he bsp_interrupt_dispatch routine does not
determine the correct interrupt source number. According to the
datasheet, the reading of the interrupt vector register (AIC_IVR)
notifies the hardware that the OS is taken care of the interrupt.
Only after AIC_IVR have been read can the correct source number be
read from the interrupt status register (AIC_ISR).
PR 1824/cpukit
* startup/bspclean.c: Return exit/shutdown status back to boot_card().
boot_card() propagates this to bsp_cleanup() and returns it to the
assembly that started the application. bsp_cleanup() prototype
changed.
PR 1824/cpukit
* misc/interr.c, spurious/spinit.c: Return exit/shutdown status back to
boot_card(). boot_card() propagates this to bsp_cleanup() and returns
it to the assembly that started the application. bsp_cleanup()
prototype changed.
PR 1824/cpukit
* include/bsp.h, startup/bspclean.c: Return exit/shutdown status back
to boot_card(). boot_card() propagates this to bsp_cleanup() and
returns it to the assembly that started the application.
bsp_cleanup() prototype changed.
PR 1824/cpukit
* startup/bspclean.c, startup/bspstart.c: Return exit/shutdown status
back to boot_card(). boot_card() propagates this to bsp_cleanup() and
PR 1824/cpukit
* bootcard.c, bspclean.c, include/bootcard.h: Return exit/shutdown
status back to boot_card(). boot_card() propagates this to
bsp_cleanup() and returns it to the assembly that started the
application.
* shared/start.S, shared/mvme/mvme16x_hw.h: Check on MVME167 at OAR
after RTC replaced.
* make/custom/beatnik.cfg: Spacing.
* libchip/serial/ns16550_p.h, libchip/serial/ns16550.c: Remove
interrupt handler during last close.
* libchip/display/disp_hcms29xx.c, libchip/flash/am29lv160.c,
libchip/i2c/i2c-2b-eeprom.c, libchip/i2c/i2c-ds1621.c,
libchip/i2c/spi-flash-m25p40.c, libchip/i2c/spi-fram-fm25l256.c,
libchip/i2c/spi-memdrv.c, libchip/rtc/ds1375.c: Eliminate use of GNU
old-style field designator extension as recommended by clang.
* libchip/i2c/spi-memdrv.h: Add missing semi-colon.
* misc/nand-mlc-erase-block-safe.c, misc/nand-mlc-write-blocks.c,
include/nand-mlc.h: Fixed write blocks.
Sebastian Huber <sebastian.huber@embedded-brains.de>
* misc/nand-mlc-erase-block-safe.c: New file
* Makefile.am: Reflect change from above.
* misc/nand-mlc-write-blocks.c: Use lpc32xx_mlc_erase_block_safe_3().
* include/nand-mlc.h: Bad block handling.
* smp/getcpuid.c: Fix header from accidental and irrelevant copy and
paste.
Jennifer Averett <jennifer.averett@OARcorp.com>
PR 1801/bsps
* shared/start.S: Add SMP support to LEON3 BSP.
PR 1801/bsps
* Makefile.am, include/leon.h: Add SMP support to LEON3 BSP.
* smp/getcpuid.c, smp/smp_leon3.c: New files.
* Makefile.am: Don't reference non-existing files.
* Makefile.am: Remove superfluous EXTRA_DIST.
* Makefile.am: Fix broken path to clockdrv_shell.h.
* Makefile.am: Fix broken path to cache_.h.
* Makefile.am: Remove references to non-existing files.
* Makefile.am: Remove reference to non-existing file times.
shared/include/utility.h.
new-exceptions/bspsupport/nest_irq_test.c.
PR 1786/bsps
* Makefile.am: Add support for Altivec.
* startup/bspstart.c, Makefile.am: Use shared/startup/zerobss.c instead.
* make/custom/mvme5500.cfg: Change CPU_CFLAGS to
"-mcpu=7450 -mtune=7450 -Dmpc7455"
* irq/BSP_irq.c, pci/detect_host_bridge.c, pci.c, pcifinddevice.c:
Remove warnings.
* vme/VMEConfig.h, include/bsp.h: use VME shared IRQ handlers.
* network/if_100MHz/GT64260eth.c: Recycle the Rx mbuf if there
is any Rx error.
