information
* shared/irq/irq_init.c, shared/openpic/openpic.h
shared/openpic/openpic.c: The 8240's EPIC has a 'serial'
mode of operation for multiplexing 16 interrupt lines.
This introduces a pipeline delay which can cause
spurious interrupts unless ending the interrupt cycle
(EOI) is delayed accordingly.
* shared/vectors/vectors.h, shared/vectors/vectors.S,
shared/vectors/vectors_init.c: Reduced size of default
prologue (some exceptions, e.g., altivec unavail.) are only
0x20 bytes apart. Also introduced a modified prologue
that switches r0..r3 shadowing off (r0..r3 undefined
on certain 603e variants when incurring a TLB miss).
* shared/irq/irq_asm.S, shared/vectors/vectors.S: Clear
CR[6] before invoking high-level handler to make sure no
varargs fn callee assumes there are FP arguments.
* shared/irq/irq.c: Fixed incorrect removal of first shared
interrupt in chain.
* bsp_specs: remove %lib.
* new-exceptions/cpu_asm.S: the book says a context
synchronizing instruction (isync) is necessary after flipping
certain bits (e.g, MSR_FP) in msr -- since this could happen as
part of a context switch I added 'isync'.
* configure.ac: Re-add mptests*Makefile.am.
* mptests/Makefile.am: Re-add mp?? tests.
* mptests/mp02/Makefile.am, mptests/mp02/node1/Makefile.am,
mptests/mp02/node2/Makefile.am, mptests/mp03/Makefile.am,
mptests/mp03/node1/Makefile.am, mptests/mp03/node2/Makefile.am,
mptests/mp04/Makefile.am, mptests/mp04/node1/Makefile.am,
mptests/mp04/node2/Makefile.am, mptests/mp05/Makefile.am,
mptests/mp05/node1/Makefile.am, mptests/mp05/node2/Makefile.am,
mptests/mp06/Makefile.am, mptests/mp06/node1/Makefile.am,
mptests/mp06/node2/Makefile.am, mptests/mp07/Makefile.am,
mptests/mp07/node1/Makefile.am, mptests/mp07/node2/Makefile.am,
mptests/mp08/Makefile.am, mptests/mp08/node1/Makefile.am,
mptests/mp08/node2/Makefile.am, mptests/mp09/Makefile.am,
mptests/mp09/node1/Makefile.am, mptests/mp09/node2/Makefile.am,
mptests/mp10/Makefile.am, mptests/mp10/node1/Makefile.am,
mptests/mp10/node2/Makefile.am, mptests/mp11/Makefile.am,
mptests/mp11/node1/Makefile.am, mptests/mp11/node2/Makefile.am,
mptests/mp12/Makefile.am, mptests/mp12/node1/Makefile.am,
mptests/mp12/node2/Makefile.am, mptests/mp13/Makefile.am,
mptests/mp13/node1/Makefile.am, mptests/mp13/node2/Makefile.am,
mptests/mp14/Makefile.am, mptests/mp14/node1/Makefile.am,
mptests/mp14/node2/Makefile.am: New.
* samples/base_mp/node1/Makefile.am,
samples/base_mp/node2/Makefile.am, samples/base_sp/Makefile.am,
samples/hello/Makefile.am, samples/ticker/Makefile.am,
sptests/sp01/Makefile.am, sptests/sp02/Makefile.am,
sptests/sp03/Makefile.am, sptests/sp04/Makefile.am,
sptests/sp05/Makefile.am, sptests/sp06/Makefile.am,
sptests/sp07/Makefile.am, sptests/sp08/Makefile.am,
sptests/sp09/Makefile.am, sptests/sp11/Makefile.am,
sptests/sp12/Makefile.am, sptests/sp13/Makefile.am,
sptests/sp14/Makefile.am, sptests/sp15/Makefile.am,
sptests/sp16/Makefile.am, sptests/sp17/Makefile.am,
sptests/sp19/Makefile.am, sptests/sp20/Makefile.am,
sptests/sp21/Makefile.am, sptests/sp22/Makefile.am,
sptests/sp23/Makefile.am, sptests/sp24/Makefile.am,
sptests/sp25/Makefile.am: Add scndir. Install *.scn to scndir.
* samples/base_mp/Makefile.am: Remove references to *.scn.
* samples/base_mp/node1/base_mp.scn: Remove.
* samples/base_mp/node1/base_mp-node1.scn: New.
* samples/base_mp/node1/Makefile.am: Eliminate NODE.
Reflect having renamed base_mp.scn.
* samples/base_mp/node2/base_mp.scn: Remove.
* samples/base_mp/node2/base_mp-node2.scn: New.
* samples/base_mp/node2/Makefile.am: Eliminate NODE.
* aclocal/prog-cc.m4: Remove RTEMS_USE_GCC.
Add RTEMS_RELLDFLAGS.
* automake/compile.am: Remove RTEMS_USE_GCC.
Remove RTEMS_RELLDFLAGS.
* configure.ac: Pass --enable-rtems-root to ada-tests/configure.
* configure.ac: Reflect changes to testsuites/automake,
testsuites/aclocal.
* rtems.adb, rtems.ads: Remove initialization directives as
rtems_initialize_executive is obsolete and the other initialization
services should not be called from Ada anyway.
* libchip/network/if_media.h, libchip/network/mii.h:
Remove (Moved to cpukit).
* libchip/Makefile.am: Reflect having moved libchip/network/mii.h
and libchip/network/if_media.h.
* libchip/network/elnk.c, libchip/network/if_dc.c: Reflect mii.h and
if_media.h having moved.
* Makefile.am: Remove depend-am.
* automake/compile.am, automake/host.am, automake/local.am,
automake/subdirs.am: Remove depend.
* configure.ac: Explicitly pass --libdir and --includedir to
testsuites.
* bsp_specs: Remove %cpp.
* console/console.c: Eliminate obsolete types.
* configure.ac: Remove USE_ENHANCED_INTR_API.
