* start/start.S: Fix mismatched comment.
* include/utility.h: More macros. Changed casts.
* console/console.c: Add baudrate support to the --console command
line option. You can now do '--console=com1,115200'.
PR 1691/bsps
* shared/include/traptable.h: Double the size of TABLE_SIZE to copy
code branched to from the trap table.
* Makefile.am: Add bspinit.c from the shared BSP files.
PR 1689/bsps
* shared/flash/intelFlash.c: Scale erase timeout by actual
system clock rate rather than assuming a fixed value.
* .cvsignore: New file.
PR 1688/libcpu
* shared/score/interrupt.S: Fix bug in the sun4u _ISR_Dispatch code
that ends up cloberring the global registers. It manifests primarily
as a memory alignment error when the globals are used to read to/from
memory.
* startup/init68360.c: Fix type punning warning.
* startup/bspstart.c: Add include to fix warning.
* network/network.c: Fix warning.
* irq/irq.h, startup/bspstart.c: Add includes to resolve warnings.
* test/tests.c: Removed file.
* startup/bspstart.c: Fixed warnings.
* console/hsu.c: Fixed warnings.
* libchip/network/greth.c, libchip/network/open_eth.c: Add constants
for buffer modes.
* shared/milkymist_ac97/ac97.c, shared/milkymist_clock/ckinit.c,
shared/milkymist_clock/clock.h, shared/milkymist_console/console.c,
shared/milkymist_console/uart.c, shared/milkymist_console/uart.h,
shared/milkymist_framebuffer/framebuffer.c,
shared/milkymist_gpio/gpio.c, shared/milkymist_networking/mm_crc32.c,
shared/milkymist_networking/network.c,
shared/milkymist_networking/network.h,
shared/milkymist_timer/timer.c: New files.
* acinclude.m4, configure.ac: Add Milkymist BSP developed as part of
GSOC 2010.
Add Milkymist BSP developed as part of GSOC 2010.
* ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
preinstall.am, Documentation/uart.txt, include/.cvsignore,
include/bsp.h, include/system_conf.h, include/tm27.h,
make/custom/milkymist.cfg, startup/linkcmds: New files.
PR 1682/bsps
* startup/bspstart.c: Add BSP_poll_char.
PR 1684/bsps
PR 1685/bsps
PR 1686/bsps
* console/console.c: Add BSP_poll_char.
PR 1681/cpukit
* shared/score/interrupt.S: With the percpu patch, ASM uses
INTERRUPT_STACK_HIGH instead of _CPU_Interrupt_stack_high. The
sparc64 was still using the old variable, which was declared in its
cpu.h file. This patch to comment out the declaration and switch to
using INTERRUPT_STACK_HIGH.
* libchip/ide/ata_internal.h: C++ compatibility.
* libchip/Makefile.am, libchip/preinstall.am: Install
<libchip/ata_internal.h>.
* libchip/ide/ata_util.c: New file.
* libchip/Makefile.am: Reflect change from above.
* libchip/ide/ata.c: Moved ata_breq_init(), ata_identify_device(), and
ata_process_request_on_init_phase() into new file.
* libchip/ide/ata_internal.h, libchip/ide/ata.c: Moved code into
separate functions. Added public ata_breq_init(),
ata_identify_device(), and ata_process_request_on_init_phase()
functions.
* src/uart-output-char.c: Add BSP_poll_char.
* shared/console/polled_io.c: Add BSP_poll_char.
* console/polled_io.c: Add BSP_poll_char.
* mpc55xx/esci/esci.c: Add BSP_poll_char.
* at91rm9200/dbgu/dbgu.c, pxa255/ffuart/ffuart.c: Add BSP_poll_char.
* Makefile.am: Do not use .rel files for libbsp pieces.
* startup/syscalls.c:
* spurious/spinit.c: Add include of bootcard.h to fix warning.
PR 1655/testing:
* ada.am: Reflect changes to testsuites/automake/compile.am.
* shared/startup/sbrk.c: Make bsp's sbrk a weak reference so that the
test of having sbrk() support in malloc can link.
* shared/startup/linkcmds: Add .gcc_except_table*.
* shared/bspgetworkarea.c: Formatting.
* console/debugio.c: Add BSP_poll_char.
* console/console.c: Add BSP_poll_char. Reformat.
PR 1599/cpukit
* sh7032/score/cpu_asm.c, sh7045/score/cpu_asm.c,
sh7750/score/cpu_asm.c, shgdb/score/cpu_asm.c: Rename
_Context_Switch_necessary to _Thread_Dispatch_necessary to more
properly reflect the intent.
PR 1599/cpukit
* new-exceptions/bspsupport/ppc_exc_hdl.c: Rename
PR 1599/cpukit
* shared/irq/exception.S: Rename _Context_Switch_necessary to
_Thread_Dispatch_necessary to more properly reflect the intent.
PR 1532/testing
* host.cfg.in: Add initial tests for untar capabilities. This required
BIN2C.
