* Makefile.am, preinstall.am: Account for coverhd.h and tm27.h. Use
stubs for both.
* acinclude.m4, beatnik: Imported/added 'beatnik'
BSP.
which included commits to RCS files with non-trunk default branches.
* shared/start/start.S: Added AltiVec support (initializing
MSR[VE], VSCR and VRSAVE).
* Makefile.am, start/start.S: Added AltiVec support
(only effective if user modifies psim.cfg: CPU_CFLAGS
choosing a CPU architecture with AltiVec or directly
adding -maltivec, -mabi=altivec).
* start/start.S: removed '.file' statement which
confused gdb.
* new-exceptions/cpu.c, new-exceptions/cpu_asm.S,
new-exceptions/bspsupport/ppc_exc_asm_macros.h,
new-exceptions/bspsupport/ppc_exc_initialize.c,
new-exceptions/bspsupport/vectors.h:
Added AltiVec support (save/restore volatile vregs
across exceptions).
* Makefile.am, mpc6xx/altivec: new directory implementing
support for AltiVec context saving/restoring.
* shared/vme/vme_universe.c: moved extern declaration
out of local scope.
* shared/startup/panic.c: Fixed compiler warning.
* shared/startup/probeMemEnd.c: removed __here_s_the_real_end
check. __rtems_end should be good enough.
* mpc6xx/mmu/bat.c, mpc6xx/mmu/pte121.c: skip data-
streaming (dssall etc.) instructions on PPC_PSIM
currently (unimplemented by PSIM :-( ).
* at91rm9200/include/at91rm9200.h: Update to match development version.
* umon/cli.h, umon/monlib.c, umon/monlib.h, umon/tfs.h,
umon/tfsDriver.c, umon/umon.h, umon/umonrtemsglue.c: Update to match
* Makefile.am, preinstall.am, console/fbcons.c, console/font8x16.h,
console/sed1356.c, console/uarts.c, include/sed1356.h,
startup/bspstart.c, startup/linkcmds.csb337, startup/linkcmds.csb637,
startup/memmap.c, startup/umonsupp.c: Update to match development
version.
* bin2s: Remove.
* bin2s.c: Remove CVS-$Log's.
* libnds/include/nds/arm9/exceptions.h,
libnds/include/nds/arm9/image.h,
libnds/include/nds/arm9/input.h,
libnds/include/nds/arm9/math.h,
libnds/include/nds/arm9/pcx.h,
libnds/include/nds/arm9/rumble.h,
libnds/include/nds/arm9/sound.h,
libnds/include/nds/arm9/trig_lut.h,
libnds/source/arm9/dcache.S,
libnds/source/arm9/exceptionHandler.S,
libnds/source/arm9/exceptions.c,
libnds/source/arm9/image.c,
libnds/source/arm9/keys.c,
libnds/source/arm9/pcx.c,
libnds/source/arm9/rumble.c,
libnds/source/arm9/sound.c,
libnds/source/arm9/system.c,
libnds/source/arm9/touch.c,
libnds/source/common/biosCalls.S,
libnds/source/common/gbfs.c,
libnds/source/common/interruptDispatcher.S,
libnds/source/common/interrupts.c:
Remove CVS-$Log's.
* shared/gdbstub/lm32-stub.c: Fix wrong computation of negative branch
targets (thanks to Manfred Scheible <mscheible@husware.de>.
* shared/tsmac/tsmac.c: Remove unused vars.
Let rtems_tsmac_driver_attach return 1.
* shared/console/console.c: Use int as return type of
BSP_uart_polled_read.
* include/bsp.h: Move extern "C" { }.
* libchip/network/smc91111.c: Formatting.
* clockdrv_shell.h: Clean up.
* shared/bsppretaskinghook.c: New file. Was really common.
* shared/bspstart.c: Removed. Was really leon2 specific.
* Makefile.am: sparc/shared/bspstart.c was really leon2 specific. So
move it here.
* startup/bspstart.c: New file.
* Makefile.am, startup/bspstart.c:
Use ../../sparc/shared/bsppretaskinghook.c.
* console/console.c: Remove sis comment.
* Makefile.am: Switch to ../../shared/bspstart.c
* clock/clockdrv.c: Split hardware initialization code into
Clock_driver_support_initialize_hardware().
* ne2000/ne2000.c: Logic on defaulting port number was inverted when
adding command line arguments.
* src/rtemsInterrupt.cc: #include <cstdlib>.
* src/rtemsMessageQueue.cc, src/rtemsSemaphore.cc,
src/rtemsTask.cc, src/rtemsTimer.cc: #include <cstring>.
* configure.ac: Check for cstdlib, cstring.
* Makefile.am, configure.ac, console/uarts.c: Add initial support for
Kit637 version of CSB637.
* README.kit637_v6, make/custom/kit637_v6.cfg: New files.
* Makefile.am, preinstall.am, at91rm9200/include/at91rm9200.h: Add
initial support for USART on at91rm9200.
* at91rm9200/include/at91rm9200_usart.h, at91rm9200/usart/usart.c:
New files.
