path: root/c (follow)
* Spacing.Joel Sherrill1999-10-123-0/+3
* Split null handlers table to own file and renamed.Joel Sherrill1999-10-1219-163/+44
| | | | Renamed IMFS handler tables to include IMFS prefix.
* Added rtems_filesystem_freenode() macro and added calls at appropriateJoel Sherrill1999-10-1235-188/+140
| | | | | places to make sure memory allocated for filesystem specifif nodes gets freed.
* Fixed spacing.Joel Sherrill1999-10-123-3/+3
* Corrected mistakes in the IMFS file handlers table and added the missingJoel Sherrill1999-10-1210-31/+301
| | | | routine imfs_fcntl.c
* Added call to freenod to let each filesystem free its own internalJoel Sherrill1999-10-1231-140/+470
| | | | node used to manage file access.
* Changed bcopy to strncpy to stick to ANSI/ISO routines.Joel Sherrill1999-10-122-2/+2
* Moved RTEMS error and association from libmisc to libc support toJoel Sherrill1999-10-117-13/+13
| | | | | avoid cyclic dependencies generated when moving packages to the top level.
* Removed targets and configurations that are no longer functionalJoel Sherrill1999-10-1114-1428/+0
| | | | | | | | | | | | | | and not likely to become so. Comments on each configuration are below. + Force CPU386 - This BSP was developed as part of the initial port of RTEMS to the i386. This board has been unavailable for a long time now. + GO32 - This BSP and some CPU code supported djgpp v1.x. This version is now quite old. No one has stepped forward to update the code to v2.x which may be technically impossible anyway. More importantly, go32 has been superceded by the pc386 BSP.
* Added as part of moving librdbg to its own top level package. This wasJoel Sherrill1999-10-116-0/+141
| | | | done as part of a patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to move librdbgJoel Sherrill1999-10-1112-131/+1081
* Now compiles for coff and elf.Joel Sherrill1999-10-111-65/+185
* New directive added -- rtems_task_is_suspended.Joel Sherrill1999-10-072-1/+77
* Added Is_Suspended method.Joel Sherrill1999-10-072-0/+20
* Removed targets and configurations that are no longer functionalJoel Sherrill1999-10-0626-5265/+0
* New file.Joel Sherrill1999-10-064-0/+56
* Removed aclocal.m4 generated from aclocal macrosJoel Sherrill1999-10-0637-27023/+0
* Removed configure generated from configure.inJoel Sherrill1999-10-0637-81630/+0
* Modified to avoid conflicts on definitions of malloc. newlib 1.8.2Joel Sherrill1999-10-067-7/+7
| | | | | | | | now prototypes the malloc family in stdlib.h. This causes conflicts with the way the network stack overrides the definitions of malloc. As best I (being Joel) can tell, commenting stdlib.h out keeps the files compiling and referencing the desired malloc/free but results in more warnings.
* Modified to explicitly list all files as part of C_PIECES.Joel Sherrill1999-10-061-1/+2
* Corrected build order so it was not as dependent on the mpc750 check.Joel Sherrill1999-10-062-6/+2
* Added sections as required by C++ and ELF.Joel Sherrill1999-10-064-3/+14
* Added more sections and made minor modifications to let the linkcmdsJoel Sherrill1999-10-068-29/+54
| | | | | work with m68k-elf on late model versions of binutils (990901+) without overlapping or missing section errors.
* Fixed spelling error (FAMILLY --> FAMILY).Joel Sherrill1999-10-061-4/+4
* Invalid value used for baud rate per bug report fromJoel Sherrill1999-10-052-2/+2
| | | | Jay Kulpinski <jskulpin@eng01.gdds.com>.
* Removed ifdef on go32.Joel Sherrill1999-10-051-1/+1
* Removed go32 ifdefsJoel Sherrill1999-10-052-6/+0
* Added comment with CVS Id.Joel Sherrill1999-10-051-0/+4
* Changed bra.s to bra.l to remove error with new version of binutils.Joel Sherrill1999-10-052-4/+4
* Changed bra.s to bra.l to correct compilation error triggered by newJoel Sherrill1999-10-052-2/+2
* Corrected so sections did not overlap with new version of binutils.Joel Sherrill1999-10-051-0/+6
* Corrected comment.Joel Sherrill1999-10-052-2/+2
* Added Jay Kulpinski (jskulpin@eng01.gdds.com) for mvme2307 BSP submission.Joel Sherrill1999-10-051-0/+6
* Removed targets and configurations that are no longer functionalJoel Sherrill1999-10-052-20/+0
* Removed targets and configurations that are no longer functionalJoel Sherrill1999-10-052-73/+1
* Removed targets and configurations that are no longer functionalJoel Sherrill1999-10-051-16/+16
* Modified to remove reference to Force CPU386. Actually this was a misnamedJoel Sherrill1999-10-051-2/+2
| | | | conditional that should have been fixed long ago.
* Modified to remove error for overlapping sections now thatJoel Sherrill1999-10-051-27/+19
| | | | gnu.linkonce* sections are included.
* Patch from Wayne Bullaughey <wayne@wmi.com>. Comments follow:Joel Sherrill1999-10-052-2/+2
| | | | | | | | | | | | I'm working on code to mount my host based file system on the base file system (imfs) and have a suggestion for a change to eval.c in the c/src/lib/libc directory of the 8/20/1999 snapshot. The current version does not test the result value returned from the evalpath callback (line 47) in the case where follow_link is true. Attached is my suggested change. Without this test the node_type callback may be called after evalpath failed. node_type could set the type to some value other then RTEMS_FILESYSTEM_HARD_LINK or RTEMS_FILESYSTEM_SYM_LINK but it seems cleaner to add the check on result.
* Removed targets and configurations that are no longer functionalJoel Sherrill1999-10-0550-4935/+0
* Added wrapup directory.Joel Sherrill1999-10-051-0/+1
* Minor corrections to get mvme2307 to compile.Joel Sherrill1999-10-0512-24/+24
* Patch from Eric Valette <valette@crf.canon.fr> with two smallJoel Sherrill1999-10-054-0/+20
| | | | fixes related to GDB over TCP/IP debug.
* Regenerated.Joel Sherrill1999-10-0574-8270/+13038
* Bug report and fix from Jay Kulpinski <jskulpin@eng01.gdds.com> whereJoel Sherrill1999-10-051-3/+2
| | | | | | sigemptyset(&old_mask) needed to be added on glibc2 systems. Ian Lance Taylor pointed out that sigemptyset() is portable so Joel removed all conditionals around calls to sigemptyset().
* Motorola MVME2307 BSP submitted by Jay Kulpinski <jskulpin@eng01.gdds.com>.Joel Sherrill1999-10-0438-0/+5142
| | | | No modifications made.
* The fiels isatty.c and creat.c were copied from newlib/libc/posix toJoel Sherrill1999-10-041-1/+2
| | | | avoid conflicts.
* Modifications necessary to support testing of exitting a pthread fromJoel Sherrill1999-10-047-66/+125
| | | | Charles-Antione Gauthier <charles.gauthier@iit.nrc.ca>.
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bugJoel Sherrill1999-10-0486-274/+274
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bugJoel Sherrill1999-10-044-4/+5
