Prevents lockup at initialization.
Modify i386/pc386 BSP to use this driver.
* libchip/network/dec21140.c: include <rtems/pci.h>.
* aclocal/rtems-cpu-subdirs.m4, libchip/shmdr/shm_driver.h,
libnetworking/pppd/utils.c: i960 obsoleted and all references
removed.
* include/bsp.h, include/tm27.h: i960 obsoleted and all references
removed.
* include/tm27.h: i960 obsoleted and all references removed.
* README: i960 obsoleted.
* i960/.cvsignore, i960/ChangeLog, i960/Makefile.am, i960/configure.ac,
i960/i960ca/.cvsignore, i960/i960ca/Makefile.am,
i960/i960ca/cpu_install_intr_stack.c,
i960/i960ca/cpu_install_raw_isr.c, i960/i960ka/.cvsignore,
i960/i960ka/Makefile.am, i960/i960ka/cpu_install_intr_stack.c,
i960/i960ka/cpu_install_raw_isr.c, i960/i960rp/.cvsignore,
i960/i960rp/Makefile.am, i960/i960rp/cpu_install_intr_stack.c,
i960/i960rp/cpu_install_raw_isr.c, i960/include/i960CA.h,
i960/include/i960HA.h, i960/include/i960JX_RP_common.h,
i960/include/i960KA.h, i960/include/i960RP.h: Removed.
* .cvsignore, ChangeLog, Makefile.am, acinclude.m4, configure.ac,
cvme961/.cvsignore, cvme961/ChangeLog, cvme961/Makefile.am,
cvme961/bsp_specs, cvme961/configure.ac, cvme961/times,
cvme961/clock/ckinit.c, cvme961/console/console.c,
cvme961/include/.cvsignore, cvme961/include/bsp.h,
cvme961/include/tm27.h, cvme961/shmsupp/addrconv.c,
cvme961/shmsupp/getcfg.c, cvme961/shmsupp/lock.c,
cvme961/shmsupp/mpisr.c, cvme961/start/start.S,
cvme961/startup/bspclean.c, cvme961/startup/bspstart.c,
cvme961/startup/exit.c, cvme961/startup/linkcmds,
cvme961/startup/setvec.c, cvme961/timer/timer.c,
cvme961/timer/timerisr.S, i960sim/.cvsignore, i960sim/ChangeLog,
i960sim/Makefile.am, i960sim/bsp_specs, i960sim/configure.ac,
i960sim/clock/clockdrv.c, i960sim/console/console-io.c,
i960sim/console/mon-syscalls.S, i960sim/include/.cvsignore,
i960sim/include/bsp.h, i960sim/include/tm27.h, i960sim/start/start.c,
i960sim/startup/bspstart.c, i960sim/startup/linkcmds,
rxgen960/.cvsignore, rxgen960/ChangeLog, rxgen960/Makefile.am,
rxgen960/README, rxgen960/bsp_specs, rxgen960/configure.ac,
rxgen960/clock/ckinit.c, rxgen960/console/concntl.h,
rxgen960/console/console.c, rxgen960/console/serial.c,
rxgen960/console/serial.h, rxgen960/include/.cvsignore,
rxgen960/include/bsp.h, rxgen960/include/rxgen960_config.h,
rxgen960/include/tm27.h, rxgen960/start/rxgen_romld.S,
rxgen960/startup/asmfault.S, rxgen960/startup/asmfault.h,
rxgen960/startup/asmstub.S, rxgen960/startup/asmstub.h,
rxgen960/startup/bspstart.c, rxgen960/startup/cntrltbl.c,
rxgen960/startup/cntrltbl.h, rxgen960/startup/dram.ld,
rxgen960/startup/exit.c, rxgen960/startup/fault.c,
rxgen960/startup/fault.h, rxgen960/startup/faultret.h,
rxgen960/startup/flttbl.c, rxgen960/startup/flttbl.h,
rxgen960/startup/frmstr.c, rxgen960/startup/frmstr.h,
rxgen960/startup/i960.h, rxgen960/startup/ihandler.S,
rxgen960/startup/ihandler.h, rxgen960/startup/intrtbl.c,
rxgen960/startup/intrtbl.h, rxgen960/startup/kkprintf.c,
rxgen960/startup/linkcmds, rxgen960/startup/linkcmds.real,
rxgen960/startup/main.h, rxgen960/startup/memchnl.h,
rxgen960/startup/nmi.c, rxgen960/startup/nulsystbl.c,
rxgen960/startup/pmc901_memmap.h, rxgen960/startup/prcb.c,
rxgen960/startup/prcb.h, rxgen960/startup/rom.ld,
rxgen960/startup/rom_cntrltbl.c, rxgen960/startup/rom_ibr.c,
rxgen960/startup/rom_ibr.h, rxgen960/startup/rom_prcb.c,
rxgen960/startup/rommon.h, rxgen960/startup/sctns.c,
rxgen960/startup/sctns.h, rxgen960/startup/setvec.c,
rxgen960/startup/systbl.c, rxgen960/startup/systbl.h,
rxgen960/startup/time.h, rxgen960/timer/timer.c,
rxgen960/timer/timerisr.S: Removed.
PR 608/bsps
* pci/pcibios.c: BusCountPCI().
PR 680/bsps
* network/if_hdlcsubr.c: Add missing #include <rtems/rtems_bsdnet.h>.
PR 606/bsps
* bootloader/pci.c: Fixed IO remapping so buses >= 1 are remapped.
Reduced PCI space to match bat2. Fixed incorrect region size
calculation in pci_read_bases. Set PCI latency timers to known
sane values. Changed bridge PCI settings to minimum sane instead
of whatever sounded neat in the PCI spec. Force pf regions to
memory mapped to preserve byte access.
PR 607/networking
* libchip/network/dec21140.c: Made PCI configuration minimum sane
instead of fully specifying unused PCI features.
PR 608/bsps
* pci/pcibios.c: Added BusCountPCI()
* aclocal/rtems-cpu-subdirs.m4: Add avr.
* aclocal/gcc-weak.m4: New (Extracted from cpukit/configure.ac).
* configure.ac: Add RTEMS_CHECK_GCC_WEAK.
* README, times, network/network.c, start/start.S, startup/bspclean.c,
startup/bspstart.c, startup/init5272.c, startup/linkcmds: Use CVS Id.
* aclocal/ppc.m4 (RTEMS_PPC_EXCEPTIONS): Quote ac_popdir uses.
* aclocal/target.m4 (_RTEMS_POP_BUILDDIR): Ditto.
* acinclude.m4 (_RTEMS_CONFIG_SUBDIR): Quote ac_popdir uses.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
times, console/.cvsignore, console/console-io.c, include/.cvsignore,
include/bsp.h, include/coverhd.h, include/tm27.h, network/network.c,
start/.cvsignore, start/start.S, startup/.cvsignore,
startup/bspclean.c, startup/bspstart.c, startup/init5272.c,
startup/linkcmds: New files.
* Makefile.am, configure.ac: Added CSB360 BSP
* mcf5272/.cvsignore, mcf5272/ChangeLog, mcf5272/Makefile.am,
mcf5272/clock/.cvsignore, mcf5272/clock/ckinit.c,
mcf5272/include/.cvsignore, mcf5272/include/mcf5272.h,
mcf5272/timer/.cvsignore, mcf5272/timer/timer.c,
mcf5272/timer/timerisr.S: New files.
* network/network.c: Changes to network driver to get it to compile
again.
* aclocal/version.m4: Updated to rtems-4.6.99.1.
* startup/linkcmds: Add gnu.linkonce.d and gcc_except_table sections.
* libchip/network/if_fxp.c: Add include of <sys/errno.h>.
* startup/linkcmds: Add gnu.linkonce.r sections.
* Makefile.am: Add -D__INSIDE_RTEMS_BSD_TCPIP_STACK__ for network.
* network/network.c: Add include of <sys/errno.h>.
* network/ne2000.c: Add include of <sys/errno.h>.
* 3c509/3c509.c: Add <sys/errno.h>.
* startup/linkcmds: Add .jcr section.
* at91rm9200/.cvsignore, mc9328mxl/.cvsignore, shared/.cvsignore:
New files.
* .cvsignore: New file.
* .cvsignore, ChangeLog, Makefile.am, configure.ac: New files.
* ChangeLog, Makefile.am, arm920/mmu.c, include/mmu.h: New files.
* ChangeLog, Makefile.am, clock/.cvsignore, clock/clockdrv.c,
include/mc9328mxl.h, irq/.cvsignore, irq/bsp_irq_asm.S,
irq/bsp_irq_init.c, irq/irq.c, irq/irq.h, timer/.cvsignore,
timer/timer.c: New files.
* ChangeLog, Makefile.am, clock/.cvsignore, clock/clock.c,
dbgu/.cvsignore, dbgu/dbgu.c, include/at91rm9200.h,
include/at91rm9200_dbgu.h, include/at91rm9200_emac.h,
include/at91rm9200_gpio.h, include/at91rm9200_mem.h,
include/at91rm9200_pmc.h, include/bits.h, irq/.cvsignore,
irq/bsp_irq_asm.S, irq/bsp_irq_init.c, irq/irq.c, irq/irq.h,
pmc/pmc.c, timer/.cvsignore, timer/timer.c: New files.
* acinclude.m4: Added csb336 and csb337 BSPs
times, console/uarts.c, include/.cvsignore, include/bsp.h,
include/tm27.h, network/.cvsignore, network/network.c,
startup/bspstart.c, startup/exit.c, startup/linkcmds,
startup/memmap.c: New files.
* console/.cvsignore, include/.cvsignore, network/.cvsignore,
start/.cvsignore, startup/.cvsignore: New files.
* ChangeLog, Makefile.am, README, bsp_specs, configure.ac, times,
console/uart.c, include/bsp.h, include/tm27.h, network/lan91c11x.c,
network/lan91c11x.h, network/network.c, start/start.S,
PR 615/bsps
* include/tm27.h: Removing USE_ENHANCE_INTR_API conditional check since
that is the only kind this BSP supports and tm27 does not care which
interrupt model is used as long as the macros are properly defined.
PR 619/bsps
* mpc6xx/clock/c_clock.c: The PPC decrementer must be reloaded on each
clock tick. Currently, this is done by just reloading a fixed value.
The attached patch takes into account the time that elapsed since the
decrementer crossed zero in order to adjust the value to be
re-loaded. Without the patch, the effective system clock cycle is
increased by the exception handler latency.
* PR 624/bsps
startup/bspstart.c: When probing the memory, make sure not to
corrupt the application. Only probe addresses beyond rtemsFreeMemStart.
* Let IBMPC_outch() convert LF -> CRLF to avoid printk scrambling
the screen.
