not updated.
timer driver
This was necessary to enable all tests to link.
You need --enable-c++ for the c++ tests.
OpenRISC/or1ksim BSP: The new sim.cfg file configures or1ksim emulator with HW
capabilities that the current RTEMS/or1ksim BSP supports.
README: HOWTO run the or1ksim simulator.
This version is distributed with SoC EDS 14.0.0.200.
counters.
The code is written as BSP specific now but it should work for all
Cortex-A and R based CPUs and can be moved to ARM generic place in future.
StackOverflow suggested sequences of writes to the registers required
to start counters is used.
http://stackoverflow.com/questions/3247373/how-to-measure-program-execution-time-in-arm-cortex-a8-processor
Adds functions that allows the user to specify which cores that should
perform the cache operation. SMP messages are sent to all the specified
cores and the caller waits until all cores have acknowledged that they
have flushed their cache. If CPU_CACHE_NO_INSTRUCTION_CACHE_SNOOPING is
defined the instruction cache invalidation function will perform the
operation on all cores using the previous method.
The flush instruction on LEON flushes both the data and the instruction
cache. Flushing of just the instruction cache can be done by setting
the "flush instruction cache" bit in the cache control register.
A secondary processor might miss changes done to the trap table
if the instruction cache is not flushed. Once interrupts are enabled
any other required cache flushes can be ordered via the cache
manager.
This patch allows the user to configure the PHY address for the DWMAC
driver by giving a pointer to a dwmac_user_cfg structure to network
stack via rtems_bsdnet_ifconfig::drv_ctrl.
BSP completes build with tests and debug enabled for all three variants now
tms570ls3137_hdk
tms570ls3137_hdk_intram
tms570ls3137_hdk_sdram
Even that all enabled tests builds for internal RAM variant, many
of them are expected to fail on hardware because whole tests
including code, data and runtime work area demands has to fit
into 256 kB of RAM.
requirements.
This patch enables to build all RTEMS tests for tms570ls3137_hdk_sdram
BSP variant in in default build. Debug build with --enable-rtems-debug set
has succeed for samples subset of tests as well.
Also cleanup:
* Remove un-needed interrupt disables.
* Address errata "e989: FLASH: Disable Prefetch during programming and erase"
* Use RTEMS_ARRAY_SIZE() macro instead of own macro.
This BSP is intended to run on or1ksim (the main OpenRISC emulator).
Fixed version according to Joel comments from the mailing list.
Included variants:
tms570ls3137_hdk_intram - place code and data into internal SRAM
tms570ls3137_hdk_sdram - place code into external SDRAM and data to SRAM
tms570ls3137_hdk - variant prepared for stand-alone RTEMS aplication
stored and running directly from flash. Not working yet.
Chip initialization code not included in BSP.
External startup generated by TI's HalCoGen was used for
testing and debugging.
More information about TMS570 BSP can be found at
http://www.rtems.org/wiki/index.php/Tms570
Patch version 2
- most of the formatting suggestion applied.
- BSP converted to use clock shell
- console driver "set attributes" tested. Baudrate change working
Patch version 3
- more formatting changes.
- removed leftover defines and test functions
Todo:
refactor header files (name register fields)
digital mode for non-analog function.
The problem wit incorrect switching of pins into analog mode manifestes
on LPC4088 based board.
LPC4088 implements pin P1.17 (ENET_MDIO) as new W type (digital pin
with analog option). The pin was listed as D category on LPC1788
which does not have analog mode control bit. If analog option is
not explicitly switched off on LPC4088 then the pin does not work
as digital pin.
Code tested on LPC1788 and no problems has been observed even that
manual specifies the IOCON_ADMODE field as reserved and should
be written as zero. But even RTEMS lpc24xx_gpio_config sets this
bit unconditionally.
Signed-off-by: Pavel Pisa <ppisa@pikron.com>
This floating point unit is available in Cortex-M4 processors and
defined by ARMv7-M. This adds basic support for other VFP-D16 variants.
Some of the headers from the hwlib need the files from the socal subdirectory.
The first pass at building these was without networking enabled.
This pass addresses that plus accounts for some new BSPs which
needed testsuite.tcfg files and BSPs which could not link tests
which had been added since the first pass.
All,
This patch is submitted as its values are used in my to-be-submitted
beagle bsp.
This prevents failures of all tests using rtems_shell_wait_for_input(),
e.g. capture, termios, pppd, etc.
Move the APBUART console driver support to the shared SPARC area so that
it can be reused by other BSPs. Only the console driver initialization
is now BSP specific.
Fix context switch on SMP for ARM, PowerPC and SPARC.
Atomically test and set the is executing indicator of the heir context
to ensure that at most one processor uses the heir context. Break the
busy wait loop also due to heir updates.
This makes it possible to use application specific version.
