* include/.cvsignore: Remove.
* include/timesys.h: Remove.
* .cvsignore: Remove.
* ChangeLog: Remove.
* Makefile.am: Remove.
* README: Remove.
* configure.ac: Remove.
* tmtests.am: Remove.
* tm01/.cvsignore: Remove.
* tm01/Makefile.am: Remove.
* tm01/system.h: Remove.
* tm01/task1.c: Remove.
* tm01/tm01.doc: Remove.
* tm02/.cvsignore: Remove.
* tm02/Makefile.am: Remove.
* tm02/system.h: Remove.
* tm02/task1.c: Remove.
* tm02/tm02.doc: Remove.
* tm03/.cvsignore: Remove.
* tm03/Makefile.am: Remove.
* tm03/system.h: Remove.
* tm03/task1.c: Remove.
* tm03/tm03.doc: Remove.
* tm04/.cvsignore: Remove.
* tm04/Makefile.am: Remove.
* tm04/system.h: Remove.
* tm04/task1.c: Remove.
* tm04/tm04.doc: Remove.
* tm05/.cvsignore: Remove.
* tm05/Makefile.am: Remove.
* tm05/system.h: Remove.
* tm05/task1.c: Remove.
* tm05/tm05.doc: Remove.
* tm06/.cvsignore: Remove.
* tm06/Makefile.am: Remove.
* tm06/system.h: Remove.
* tm06/task1.c: Remove.
* tm06/tm06.doc: Remove.
* tm07/.cvsignore: Remove.
* tm07/Makefile.am: Remove.
* tm07/system.h: Remove.
* tm07/task1.c: Remove.
* tm07/tm07.doc: Remove.
* tm08/.cvsignore: Remove.
* tm08/Makefile.am: Remove.
* tm08/system.h: Remove.
* tm08/task1.c: Remove.
* tm08/tm08.doc: Remove.
* tm09/.cvsignore: Remove.
* tm09/Makefile.am: Remove.
* tm09/system.h: Remove.
* tm09/task1.c: Remove.
* tm09/tm09.doc: Remove.
* tm10/.cvsignore: Remove.
* tm10/Makefile.am: Remove.
* tm10/system.h: Remove.
* tm10/task1.c: Remove.
* tm10/tm10.doc: Remove.
* tm11/.cvsignore: Remove.
* tm11/Makefile.am: Remove.
* tm11/system.h: Remove.
* tm11/task1.c: Remove.
* tm11/tm11.doc: Remove.
* tm12/.cvsignore: Remove.
* tm12/Makefile.am: Remove.
* tm12/system.h: Remove.
* tm12/task1.c: Remove.
* tm12/tm12.doc: Remove.
* tm13/.cvsignore: Remove.
* tm13/Makefile.am: Remove.
* tm13/system.h: Remove.
* tm13/task1.c: Remove.
* tm13/tm13.doc: Remove.
* tm14/.cvsignore: Remove.
* tm14/Makefile.am: Remove.
* tm14/system.h: Remove.
* tm14/task1.c: Remove.
* tm14/tm14.doc: Remove.
* tm15/.cvsignore: Remove.
* tm15/Makefile.am: Remove.
* tm15/system.h: Remove.
* tm15/task1.c: Remove.
* tm15/tm15.doc: Remove.
* tm16/.cvsignore: Remove.
* tm16/Makefile.am: Remove.
* tm16/system.h: Remove.
* tm16/task1.c: Remove.
* tm16/tm16.doc: Remove.
* tm17/.cvsignore: Remove.
* tm17/Makefile.am: Remove.
* tm17/system.h: Remove.
* tm17/task1.c: Remove.
* tm17/tm17.doc: Remove.
* tm18/.cvsignore: Remove.
* tm18/Makefile.am: Remove.
* tm18/system.h: Remove.
* tm18/task1.c: Remove.
* tm18/tm18.doc: Remove.
* tm19/.cvsignore: Remove.
* tm19/Makefile.am: Remove.
* tm19/system.h: Remove.
* tm19/task1.c: Remove.
* tm19/tm19.doc: Remove.
* tm20/.cvsignore: Remove.
* tm20/Makefile.am: Remove.
* tm20/system.h: Remove.
* tm20/task1.c: Remove.
* tm20/tm20.doc: Remove.
* tm21/.cvsignore: Remove.
* tm21/Makefile.am: Remove.
* tm21/system.h: Remove.
* tm21/task1.c: Remove.
* tm21/tm21.doc: Remove.
* tm22/.cvsignore: Remove.
* tm22/Makefile.am: Remove.
* tm22/system.h: Remove.
* tm22/task1.c: Remove.
* tm22/tm22.doc: Remove.
* tm23/.cvsignore: Remove.
* tm23/Makefile.am: Remove.
* tm23/system.h: Remove.
* tm23/task1.c: Remove.
* tm23/tm23.doc: Remove.
* tm24/.cvsignore: Remove.
* tm24/Makefile.am: Remove.
* tm24/system.h: Remove.
* tm24/task1.c: Remove.
* tm24/tm24.doc: Remove.
* tm25/.cvsignore: Remove.
* tm25/Makefile.am: Remove.
* tm25/system.h: Remove.
* tm25/task1.c: Remove.
* tm25/tm25.doc: Remove.
* tm26/.cvsignore: Remove.
* tm26/Makefile.am: Remove.
* tm26/fptest.h: Remove.
* tm26/system.h: Remove.
* tm26/task1.c: Remove.
* tm26/tm26.doc: Remove.
* tm27/.cvsignore: Remove.
* tm27/Makefile.am: Remove.
* tm27/system.h: Remove.
* tm27/task1.c: Remove.
* tm27/tm27.doc: Remove.
* tm28/.cvsignore: Remove.
* tm28/Makefile.am: Remove.
* tm28/system.h: Remove.
* tm28/task1.c: Remove.
* tm28/tm28.doc: Remove.
* tm29/.cvsignore: Remove.
* tm29/Makefile.am: Remove.
* tm29/system.h: Remove.
* tm29/task1.c: Remove.
* tm29/tm29.doc: Remove.
* tmck/.cvsignore: Remove.
* tmck/Makefile.am: Remove.
* tmck/system.h: Remove.
* tmck/task1.c: Remove.
* tmck/tmck.doc: Remove.
* tmoverhd/.cvsignore: Remove.
* tmoverhd/Makefile.am: Remove.
* tmoverhd/dumrtems.h: Remove.
* tmoverhd/empty.c: Remove.
* tmoverhd/system.h: Remove.
* tmoverhd/testtask.c: Remove.
* tmoverhd/tmoverhd.doc: Remove.
tm01/Makefile.am: Reflect having moved automake.
tm02/Makefile.am: Reflect having moved automake.
tm03/Makefile.am: Reflect having moved automake.
tm04/Makefile.am: Reflect having moved automake.
tm05/Makefile.am: Reflect having moved automake.
tm06/Makefile.am: Reflect having moved automake.
tm07/Makefile.am: Reflect having moved automake.
tm08/Makefile.am: Reflect having moved automake.
tm09/Makefile.am: Reflect having moved automake.
tm10/Makefile.am: Reflect having moved automake.
tm11/Makefile.am: Reflect having moved automake.
tm12/Makefile.am: Reflect having moved automake.
tm13/Makefile.am: Reflect having moved automake.
tm14/Makefile.am: Reflect having moved automake.
tm15/Makefile.am: Reflect having moved automake.
tm16/Makefile.am: Reflect having moved automake.
tm17/Makefile.am: Reflect having moved automake.
tm18/Makefile.am: Reflect having moved automake.
tm19/Makefile.am: Reflect having moved automake.
tm20/Makefile.am: Reflect having moved automake.
tm21/Makefile.am: Reflect having moved automake.
tm22/Makefile.am: Reflect having moved automake.
tm23/Makefile.am: Reflect having moved automake.
tm24/Makefile.am: Reflect having moved automake.
tm25/Makefile.am: Reflect having moved automake.
tm26/Makefile.am: Reflect having moved automake.
tm27/Makefile.am: Reflect having moved automake.
tm28/Makefile.am: Reflect having moved automake.
tm29/Makefile.am: Reflect having moved automake.
tmck/Makefile.am: Reflect having moved automake.
tmoverhd/Makefile.am: Reflect having moved automake.
* tm01/Makefile.am: Use $(OBJEXT) instead of .o.
* tm02/Makefile.am: Use $(OBJEXT) instead of .o.
* tm03/Makefile.am: Use $(OBJEXT) instead of .o.
* tm04/Makefile.am: Use $(OBJEXT) instead of .o.
* tm05/Makefile.am: Use $(OBJEXT) instead of .o.
* tm06/Makefile.am: Use $(OBJEXT) instead of .o.
* tm07/Makefile.am: Use $(OBJEXT) instead of .o.
* tm08/Makefile.am: Use $(OBJEXT) instead of .o.
* tm09/Makefile.am: Use $(OBJEXT) instead of .o.
* tm10/Makefile.am: Use $(OBJEXT) instead of .o.
* tm11/Makefile.am: Use $(OBJEXT) instead of .o.
* tm12/Makefile.am: Use $(OBJEXT) instead of .o.
* tm13/Makefile.am: Use $(OBJEXT) instead of .o.
* tm14/Makefile.am: Use $(OBJEXT) instead of .o.
* tm15/Makefile.am: Use $(OBJEXT) instead of .o.
* tm16/Makefile.am: Use $(OBJEXT) instead of .o.
* tm17/Makefile.am: Use $(OBJEXT) instead of .o.
* tm18/Makefile.am: Use $(OBJEXT) instead of .o.
* tm19/Makefile.am: Use $(OBJEXT) instead of .o.
* tm20/Makefile.am: Use $(OBJEXT) instead of .o.
* tm21/Makefile.am: Use $(OBJEXT) instead of .o.
* tm22/Makefile.am: Use $(OBJEXT) instead of .o.
* tm23/Makefile.am: Use $(OBJEXT) instead of .o.
* tm24/Makefile.am: Use $(OBJEXT) instead of .o.
* tm25/Makefile.am: Use $(OBJEXT) instead of .o.
* tm26/Makefile.am: Use $(OBJEXT) instead of .o.
* tm27/Makefile.am: Use $(OBJEXT) instead of .o.
* tm28/Makefile.am: Use $(OBJEXT) instead of .o.
* tm29/Makefile.am: Use $(OBJEXT) instead of .o.
* tmck/Makefile.am: Use $(OBJEXT) instead of .o.
* tmoverhd/Makefile.am: Use $(OBJEXT) instead of .o.
* tm01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm02/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm03/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm04/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm05/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm06/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm07/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm08/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm09/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm10/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm11/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm12/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm13/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm14/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm15/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm16/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm17/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm18/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm19/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm20/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm21/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm22/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm23/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm24/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm25/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm26/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm27/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm28/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm29/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tmck/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tmoverhd/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm27/Makefile.am: include leaf.am instead of leaf.cfg.
* tm26/Makefile.am: include leaf.am instead of leaf.cfg.
* tm24/Makefile.am: include leaf.am instead of leaf.cfg.
* tm16/Makefile.am: include leaf.am instead of leaf.cfg.
* tm18/Makefile.am: include leaf.am instead of leaf.cfg.
* tm02/Makefile.am: include leaf.am instead of leaf.cfg.
* tm10/Makefile.am: include leaf.am instead of leaf.cfg.
* tm11/Makefile.am: include leaf.am instead of leaf.cfg.
* tm15/Makefile.am: include leaf.am instead of leaf.cfg.
* tm19/Makefile.am: include leaf.am instead of leaf.cfg.
* tm04/Makefile.am: include leaf.am instead of leaf.cfg.
* tm17/Makefile.am: include leaf.am instead of leaf.cfg.
* tm28/Makefile.am: include leaf.am instead of leaf.cfg.
* tmck/Makefile.am: include leaf.am instead of leaf.cfg.
* tm08/Makefile.am: include leaf.am instead of leaf.cfg.
* tm12/Makefile.am: include leaf.am instead of leaf.cfg.
* tm03/Makefile.am: include leaf.am instead of leaf.cfg.
* tm13/Makefile.am: include leaf.am instead of leaf.cfg.
* tm29/Makefile.am: include leaf.am instead of leaf.cfg.
* tmoverhd/Makefile.am: include leaf.am instead of leaf.cfg.
* tm20/Makefile.am: include leaf.am instead of leaf.cfg.
* tm09/Makefile.am: include leaf.am instead of leaf.cfg.
* tm01/Makefile.am: include leaf.am instead of leaf.cfg.
* tm21/Makefile.am: include leaf.am instead of leaf.cfg.
* tm07/Makefile.am: include leaf.am instead of leaf.cfg.
* tm25/Makefile.am: include leaf.am instead of leaf.cfg.
* tm22/Makefile.am: include leaf.am instead of leaf.cfg.
* tm06/Makefile.am: include leaf.am instead of leaf.cfg.
* tm05/Makefile.am: include leaf.am instead of leaf.cfg.
* tm14/Makefile.am: include leaf.am instead of leaf.cfg.
* tm23/Makefile.am: include leaf.am instead of leaf.cfg.
* tm20/Makefile.am: Remove stubdir.rel
* tm01/Makefile.am, tm02/Makefile.am, tm03/Makefile.am,
tm04/Makefile.am, tm05/Makefile.am, tm06/Makefile.am,
tm07/Makefile.am, tm08/Makefile.am, tm09/Makefile.am,
tm10/Makefile.am, tm11/Makefile.am, tm12/Makefile.am,
tm13/Makefile.am, tm14/Makefile.am, tm15/Makefile.am,
tm16/Makefile.am, tm17/Makefile.am, tm18/Makefile.am,
tm19/Makefile.am, tm20/Makefile.am, tm21/Makefile.am,
tm22/Makefile.am, tm23/Makefile.am, tm24/Makefile.am,
tm25/Makefile.am, tm26/Makefile.am, tm27/Makefile.am,
tm28/Makefile.am, tm29/Makefile.am, tmck/Makefile.am,
tmoverhd/Makefile.am: Include compile.am
Addtional major bugs:
to convert the tmtests directory from Makefile.in to Makefile.am.
