* include/.cvsignore: Remove.
* include/timesys.h: Remove.
* .cvsignore: Remove.
* ChangeLog: Remove.
* Makefile.am: Remove.
* README: Remove.
* configure.ac: Remove.
* tmitrontests.am: Remove.
* tmitronsem01/.cvsignore: Remove.
* tmitronsem01/Makefile.am: Remove.
* tmitronsem01/init.c: Remove.
* tmitronsem01/system.h: Remove.
* tmitronsem01/tmitronsem01.doc: Remove.
* include/timesys.h, tmitronsem01/init.c, tmitronsem01/system.h,
tmitronsem01/tmitronsem01.doc: URL for license changed.
enable this support.
* tmitronsem01/init.c: Modified.
for RTEMS.
