* | 2003-11-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-11 | 1 | -229/+0 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * base_mp/node1/.cvsignore: Remove. * base_mp/node1/Makefile.am: Remove. * base_mp/node1/base_mp.doc: Remove. * base_mp/node1/base_mp.scn: Remove. * base_mp/.cvsignore: Remove. * base_mp/Makefile.am: Remove. * base_mp/apptask.c: Remove. * base_mp/init.c: Remove. * base_mp/system.h: Remove. * base_mp/node2/.cvsignore: Remove. * base_mp/node2/Makefile.am: Remove. * base_mp/node2/base_mp.doc: Remove. * base_mp/node2/base_mp.scn: Remove. * .cvsignore: Remove. * ChangeLog: Remove. * Makefile.am: Remove. * README: Remove. * configure.ac: Remove. * sample.am: Remove. * base_sp/.cvsignore: Remove. * base_sp/Makefile.am: Remove. * base_sp/apptask.c: Remove. * base_sp/base_sp.doc: Remove. * base_sp/base_sp.scn: Remove. * base_sp/init.c: Remove. * base_sp/system.h: Remove. * cdtest/.cvsignore: Remove. * cdtest/Makefile.am: Remove. * cdtest/cdtest.scn: Remove. * cdtest/init.c: Remove. * cdtest/main.cc: Remove. * cdtest/system.h: Remove. * fileio/.cvsignore: Remove. * fileio/Makefile.am: Remove. * fileio/fileio.doc: Remove. * fileio/init.c: Remove. * fileio/system.h: Remove. * hello/.cvsignore: Remove. * hello/Makefile.am: Remove. * hello/hello.doc: Remove. * hello/hello.scn: Remove. * hello/init.c: Remove. * hello/system.h: Remove. * loopback/.cvsignore: Remove. * loopback/Makefile.am: Remove. * loopback/README: Remove. * loopback/init.c: Remove. * loopback/loopback.scn: Remove. * minimum/.cvsignore: Remove. * minimum/Makefile.am: Remove. * minimum/init.c: Remove. * minimum/minimum.doc: Remove. * minimum/minimum.scn: Remove. * paranoia/.cvsignore: Remove. * paranoia/Makefile.am: Remove. * paranoia/init.c: Remove. * paranoia/paranoia.c: Remove. * paranoia/paranoia.doc: Remove. * paranoia/system.h: Remove. * pppd/.cvsignore: Remove. * pppd/Makefile-user: Remove. * pppd/Makefile.am: Remove. * pppd/README: Remove. * pppd/init.c: Remove. * pppd/netconfig.h: Remove. * pppd/ppp.conf: Remove. * pppd/pppd.options: Remove. * pppd/pppdapp.c: Remove. * pppd/system.h: Remove. * ticker/.cvsignore: Remove. * ticker/Makefile.am: Remove. * ticker/init.c: Remove. * ticker/system.h: Remove. * ticker/tasks.c: Remove. * ticker/ticker.doc: Remove. * ticker/ticker.scn: Remove. * unlimited/.cvsignore: Remove. * unlimited/Makefile.am: Remove. * unlimited/init.c: Remove. * unlimited/system.h: Remove. * unlimited/test1.c: Remove. * unlimited/test2.c: Remove. * unlimited/test3.c: Remove. * unlimited/unlimited.doc: Remove. * unlimited/unlimited.scn: Remove. | ||||
| | | | | | | | | | | | | | | * README, base_mp/apptask.c, base_mp/init.c, base_mp/system.h, base_mp/node1/base_mp.doc, base_mp/node2/base_mp.doc, base_sp/apptask.c, base_sp/base_sp.doc, base_sp/init.c, base_sp/system.h, cdtest/init.c, cdtest/main.cc, cdtest/system.h, fileio/fileio.doc, fileio/init.c, fileio/system.h, hello/hello.doc, hello/init.c, hello/system.h, minimum/init.c, minimum/minimum.doc, paranoia/init.c, paranoia/paranoia.doc, paranoia/system.h, ticker/init.c, ticker/system.h, ticker/tasks.c, ticker/ticker.doc, unlimited/init.c, unlimited/system.h, unlimited/test1.c, unlimited/test2.c, unlimited/test3.c, unlimited/unlimited.doc: URL for license changed. | ||||
* | 2002-04-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-04-17 | 1 | -0/+1 |
| | | | | | | | | | | | * base_sp/apptask.c: Include <stdlib.h>. * hello/init.c: Ditto. * paranoia/init.c: Ditto. * ticker/tasks.c: Ditto. * unlimited/init.c: Ditto. * unlimited/test1.c: Ditto. * unlimited/test2.c: Ditto. * unlimited/test3.c: Ditto. | ||||
* | 2001-10-12 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-10-12 | 1 | -1/+0 |
| | | | | | | * unlimited/init.c, unlimited/system.h, unlimited/test1.c, unlimited/test2.c, unlimited/test3.c, unlimited/unlimited.doc: Fixed typo. | ||||
* | Modified to use minimum stack size and reserve the necessary amount | Joel Sherrill | 1999-11-02 | 1 | -2/+3 |
| | | | | of space in the workspace. | ||||
* | Unlimited objects patch from Chris Johns <ccj@acm.org>. Email follows: | Joel Sherrill | 1999-03-17 | 1 | -0/+228 |
First, the unlimited patch. I have compiled the unlmited patch for the Linux posix BSP only and it seems to work cleanly. I would like a really major application run on this change before commiting as the changes are very core and significant. I am currently building all the tests to run. I have no targets suitable to test on at the moment. I have tested the patch for inline functions and macros. Turning macros on has found some core bugs. I have fixed these but have not run all the tests. Please review the patch for these changes. They are: 1) The conditional compilation for MP support broke the core messages code. You cannot embed a conditional macro in another macro. The Send and Urgent Send calls are macros. 2) User extensions handler initialisation now has two parameters. I have updated the macros to support the extra parameter. The patch also contains the gcc-target-default.cfg fix required to build the kernel. More of a by product than a fix for you. |
