* | 2003-11-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-11 | 1 | -27/+0 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * base_mp/node1/.cvsignore: Remove. * base_mp/node1/Makefile.am: Remove. * base_mp/node1/base_mp.doc: Remove. * base_mp/node1/base_mp.scn: Remove. * base_mp/.cvsignore: Remove. * base_mp/Makefile.am: Remove. * base_mp/apptask.c: Remove. * base_mp/init.c: Remove. * base_mp/system.h: Remove. * base_mp/node2/.cvsignore: Remove. * base_mp/node2/Makefile.am: Remove. * base_mp/node2/base_mp.doc: Remove. * base_mp/node2/base_mp.scn: Remove. * .cvsignore: Remove. * ChangeLog: Remove. * Makefile.am: Remove. * README: Remove. * configure.ac: Remove. * sample.am: Remove. * base_sp/.cvsignore: Remove. * base_sp/Makefile.am: Remove. * base_sp/apptask.c: Remove. * base_sp/base_sp.doc: Remove. * base_sp/base_sp.scn: Remove. * base_sp/init.c: Remove. * base_sp/system.h: Remove. * cdtest/.cvsignore: Remove. * cdtest/Makefile.am: Remove. * cdtest/cdtest.scn: Remove. * cdtest/init.c: Remove. * cdtest/main.cc: Remove. * cdtest/system.h: Remove. * fileio/.cvsignore: Remove. * fileio/Makefile.am: Remove. * fileio/fileio.doc: Remove. * fileio/init.c: Remove. * fileio/system.h: Remove. * hello/.cvsignore: Remove. * hello/Makefile.am: Remove. * hello/hello.doc: Remove. * hello/hello.scn: Remove. * hello/init.c: Remove. * hello/system.h: Remove. * loopback/.cvsignore: Remove. * loopback/Makefile.am: Remove. * loopback/README: Remove. * loopback/init.c: Remove. * loopback/loopback.scn: Remove. * minimum/.cvsignore: Remove. * minimum/Makefile.am: Remove. * minimum/init.c: Remove. * minimum/minimum.doc: Remove. * minimum/minimum.scn: Remove. * paranoia/.cvsignore: Remove. * paranoia/Makefile.am: Remove. * paranoia/init.c: Remove. * paranoia/paranoia.c: Remove. * paranoia/paranoia.doc: Remove. * paranoia/system.h: Remove. * pppd/.cvsignore: Remove. * pppd/Makefile-user: Remove. * pppd/Makefile.am: Remove. * pppd/README: Remove. * pppd/init.c: Remove. * pppd/netconfig.h: Remove. * pppd/ppp.conf: Remove. * pppd/pppd.options: Remove. * pppd/pppdapp.c: Remove. * pppd/system.h: Remove. * ticker/.cvsignore: Remove. * ticker/Makefile.am: Remove. * ticker/init.c: Remove. * ticker/system.h: Remove. * ticker/tasks.c: Remove. * ticker/ticker.doc: Remove. * ticker/ticker.scn: Remove. * unlimited/.cvsignore: Remove. * unlimited/Makefile.am: Remove. * unlimited/init.c: Remove. * unlimited/system.h: Remove. * unlimited/test1.c: Remove. * unlimited/test2.c: Remove. * unlimited/test3.c: Remove. * unlimited/unlimited.doc: Remove. * unlimited/unlimited.scn: Remove. | ||||
* | 2003-04-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-04-29 | 1 | -0/+27 |
Adding pppd: * pppd/Makefile-user: New, copied over from libnetworking/pppd/example. * pppd/README: New, copied over from libnetworking/pppd/example. * pppd/init.c: New, copied over from libnetworking/pppd/example. * pppd/netconfig.h: New, copied over from libnetworking/pppd/example. * pppd/ppp.conf: New, copied over from libnetworking/pppd/example. * pppd/pppdapp.c: New, copied over from libnetworking/pppd/example. * pppd/system.h: New, copied over from libnetworking/pppd/example. * pppd/pppd.options: New, copied over from libnetworking/pppd/example. * pppd/Makefile.am: New, converted to automake from Makefile-user. * pppd/.cvsignore: New. |
