* base_mp/node1/.cvsignore: Remove.
* base_mp/node1/Makefile.am: Remove.
* base_mp/node1/base_mp.doc: Remove.
* base_mp/node1/base_mp.scn: Remove.
* base_mp/.cvsignore: Remove.
* base_mp/Makefile.am: Remove.
* base_mp/apptask.c: Remove.
* base_mp/init.c: Remove.
* base_mp/system.h: Remove.
* base_mp/node2/.cvsignore: Remove.
* base_mp/node2/Makefile.am: Remove.
* base_mp/node2/base_mp.doc: Remove.
* base_mp/node2/base_mp.scn: Remove.
* .cvsignore: Remove.
* ChangeLog: Remove.
* Makefile.am: Remove.
* README: Remove.
* configure.ac: Remove.
* sample.am: Remove.
* base_sp/.cvsignore: Remove.
* base_sp/Makefile.am: Remove.
* base_sp/apptask.c: Remove.
* base_sp/base_sp.doc: Remove.
* base_sp/base_sp.scn: Remove.
* base_sp/init.c: Remove.
* base_sp/system.h: Remove.
* cdtest/.cvsignore: Remove.
* cdtest/Makefile.am: Remove.
* cdtest/cdtest.scn: Remove.
* cdtest/init.c: Remove.
* cdtest/main.cc: Remove.
* cdtest/system.h: Remove.
* fileio/.cvsignore: Remove.
* fileio/Makefile.am: Remove.
* fileio/fileio.doc: Remove.
* fileio/init.c: Remove.
* fileio/system.h: Remove.
* hello/.cvsignore: Remove.
* hello/Makefile.am: Remove.
* hello/hello.doc: Remove.
* hello/hello.scn: Remove.
* hello/init.c: Remove.
* hello/system.h: Remove.
* loopback/.cvsignore: Remove.
* loopback/Makefile.am: Remove.
* loopback/README: Remove.
* loopback/init.c: Remove.
* loopback/loopback.scn: Remove.
* minimum/.cvsignore: Remove.
* minimum/Makefile.am: Remove.
* minimum/init.c: Remove.
* minimum/minimum.doc: Remove.
* minimum/minimum.scn: Remove.
* paranoia/.cvsignore: Remove.
* paranoia/Makefile.am: Remove.
* paranoia/init.c: Remove.
* paranoia/paranoia.c: Remove.
* paranoia/paranoia.doc: Remove.
* paranoia/system.h: Remove.
* pppd/.cvsignore: Remove.
* pppd/Makefile-user: Remove.
* pppd/Makefile.am: Remove.
* pppd/README: Remove.
* pppd/init.c: Remove.
* pppd/netconfig.h: Remove.
* pppd/ppp.conf: Remove.
* pppd/pppd.options: Remove.
* pppd/pppdapp.c: Remove.
* pppd/system.h: Remove.
* ticker/.cvsignore: Remove.
* ticker/Makefile.am: Remove.
* ticker/init.c: Remove.
* ticker/system.h: Remove.
* ticker/tasks.c: Remove.
* ticker/ticker.doc: Remove.
* ticker/ticker.scn: Remove.
* unlimited/.cvsignore: Remove.
* unlimited/Makefile.am: Remove.
* unlimited/init.c: Remove.
* unlimited/system.h: Remove.
* unlimited/test1.c: Remove.
* unlimited/test2.c: Remove.
* unlimited/test3.c: Remove.
* unlimited/unlimited.doc: Remove.
* unlimited/unlimited.scn: Remove.
base_mp/Makefile.am: Reflect having moved automake.
base_mp/node1/Makefile.am: Reflect having moved automake.
base_mp/node2/Makefile.am: Reflect having moved automake.
base_sp/Makefile.am: Reflect having moved automake.
cdtest/Makefile.am: Reflect having moved automake.
fileio/Makefile.am: Reflect having moved automake.
hello/Makefile.am: Reflect having moved automake.
loopback/Makefile.am: Reflect having moved automake.
minimum/Makefile.am: Reflect having moved automake.
paranoia/Makefile.am: Reflect having moved automake.
pppd/Makefile.am: Reflect having moved automake.
ticker/Makefile.am: Reflect having moved automake.
unlimited/Makefile.am: Reflect having moved automake.
* base_mp/node1/Makefile.am: Use .$(OBJEXT) instead of .o.
* base_mp/node2/Makefile.am: Use .$(OBJEXT) instead of .o.
* base_sp/Makefile.am: Use .$(OBJEXT) instead of .o.
* cdtest/Makefile.am: Use .$(OBJEXT) instead of .o.
* hello/Makefile.am: Use .$(OBJEXT) instead of .o.
* minimum/Makefile.am: Use .$(OBJEXT) instead of .o.
* paranoia/Makefile.am: Use .$(OBJEXT) instead of .o.
* ticker/Makefile.am: Use .$(OBJEXT) instead of .o.
* unlimited/Makefile.am: Use .$(OBJEXT) instead of .o.
* base_mp/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_mp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_mp/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_sp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* cdtest/Makefile.am: Remove AUTOMAKE_OPTIONS.
* hello/Makefile.am: Remove AUTOMAKE_OPTIONS.
* minimum/Makefile.am: Remove AUTOMAKE_OPTIONS.
* paranoia/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ticker/Makefile.am: Remove AUTOMAKE_OPTIONS.
* unlimited/Makefile.am: Remove AUTOMAKE_OPTIONS.
* unlimited/Makefile.am: include leaf.am instead of leaf.cfg.
* base_mp/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* base_mp/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* hello/Makefile.am: include leaf.am instead of leaf.cfg.
* base_sp/Makefile.am: include leaf.am instead of leaf.cfg.
* paranoia/Makefile.am: include leaf.am instead of leaf.cfg.
* cdtest/Makefile.am: include leaf.am instead of leaf.cfg, use
make-cxx-exe.
* ticker/Makefile.am: include leaf.am instead of leaf.cfg.
* minimum/Makefile.am: include leaf.am instead of leaf.cfg.
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am,
base_sp/Makefile.am, cdtest/Makefile.am, hello/Makefile.am,
minimum/Makefile.am, paranoia/Makefile.am, ticker/Makefile.am,
unlimited/Makefile.am: Include compile.am
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
which ontains all what was left over from the other patches (Primarily
minor configuration cleanups).
patch -p1 < rtems-rc-19991203-9.diff
./bootstrap
to convert the sample tests to automake.
