* | 2003-11-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-11 | 1 | -62/+0 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * itronhello/.cvsignore: Remove. * itronhello/Makefile.am: Remove. * itronhello/init.c: Remove. * itronhello/itronhello.doc: Remove. * itronhello/itronhello.scn: Remove. * itronhello/system.h: Remove. * .cvsignore: Remove. * ChangeLog: Remove. * Makefile.am: Remove. * README: Remove. * configure.ac: Remove. * itrontests.am: Remove. * itronmbf01/.cvsignore: Remove. * itronmbf01/Makefile.am: Remove. * itronmbf01/init.c: Remove. * itronmbf01/itronmbf01.doc: Remove. * itronmbf01/itronmbf01.scn: Remove. * itronmbf01/system.h: Remove. * itronmbox01/.cvsignore: Remove. * itronmbox01/Makefile.am: Remove. * itronmbox01/init.c: Remove. * itronmbox01/itronmbox01.doc: Remove. * itronmbox01/itronmbox01.scn: Remove. * itronmbox01/system.h: Remove. * itronsem01/.cvsignore: Remove. * itronsem01/Makefile.am: Remove. * itronsem01/init.c: Remove. * itronsem01/itronsem01.doc: Remove. * itronsem01/itronsem01.scn: Remove. * itronsem01/system.h: Remove. * itrontask01/.cvsignore: Remove. * itrontask01/Makefile.am: Remove. * itrontask01/init.c: Remove. * itrontask01/itrontask01.doc: Remove. * itrontask01/itrontask01.scn: Remove. * itrontask01/system.h: Remove. * itrontask01/task1.c: Remove. * itrontask02/.cvsignore: Remove. * itrontask02/Makefile.am: Remove. * itrontask02/dormant.c: Remove. * itrontask02/init.c: Remove. * itrontask02/itrontask02.doc: Remove. * itrontask02/itrontask02.scn: Remove. * itrontask02/system.h: Remove. * itrontask03/.cvsignore: Remove. * itrontask03/Makefile.am: Remove. * itrontask03/init.c: Remove. * itrontask03/itrontask03.doc: Remove. * itrontask03/itrontask03.scn: Remove. * itrontask03/preempt.c: Remove. * itrontask03/system.h: Remove. * itrontask03/task1.c: Remove. * itrontask03/task2.c: Remove. * itrontask03/task3.c: Remove. * itrontask04/.cvsignore: Remove. * itrontask04/Makefile.am: Remove. * itrontask04/init.c: Remove. * itrontask04/itrontask04.doc: Remove. * itrontask04/itrontask04.scn: Remove. * itrontask04/system.h: Remove. * itrontask04/task1.c: Remove. * itrontask04/task2.c: Remove. * itrontask04/task3.c: Remove. * itrontime01/.cvsignore: Remove. * itrontime01/Makefile.am: Remove. * itrontime01/init.c: Remove. * itrontime01/itrontime01.doc: Remove. * itrontime01/itrontime01.scn: Remove. * itrontime01/system.h: Remove. | ||||
| | | | | | | | | | | | | | | | | * itronhello/init.c, itronhello/itronhello.doc, itronhello/system.h, itronmbf01/init.c, itronmbf01/itronmbf01.doc, itronmbf01/system.h, itronmbox01/init.c, itronmbox01/system.h, itronsem01/init.c, itronsem01/itronsem01.doc, itronsem01/system.h, itrontask01/init.c, itrontask01/itrontask01.doc, itrontask01/system.h, itrontask01/task1.c, itrontask02/dormant.c, itrontask02/init.c, itrontask02/itrontask02.doc, itrontask02/system.h, itrontask03/init.c, itrontask03/itrontask03.doc, itrontask03/preempt.c, itrontask03/system.h, itrontask03/task1.c, itrontask03/task2.c, itrontask03/task3.c, itrontask04/init.c, itrontask04/itrontask04.doc, itrontask04/system.h, itrontask04/task1.c, itrontask04/task2.c, itrontask04/task3.c, itrontime01/init.c, itrontime01/system.h: URL for license changed. | ||||
* | 2002-08-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-02 | 1 | -1/+1 |
| | | | | | | | | | | | | | * Per PR47 add support for buffered test output. This involved adding defines to redirect output to a buffer and dump it when full, at "test pause", and at exit. To avoid problems when redefining exit(), all tests were modified to call rtems_test_exit(). Some tests, notable psxtests, had to be modified to include the standard test macro .h file (pmacros.h or tmacros.h) to enable this support. * itronhello/init.c, itronmbf01/init.c, itronmbox01/init.c, itronsem01/init.c, itrontask01/task1.c, itrontask02/init.c, itrontask03/task1.c, itrontask04/task3.c, itrontime01/init.c: Modified. | ||||
* | 2001-04-20 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-04-20 | 1 | -1/+1 |
| | | | | | | * itronmbf01/itronmbf01.scn, itronmbox01/init.c, itronsem01/itronsem01.scn, itrontime01/init.c: Various adjustments so test output matches screens more reliably. | ||||
* | Fixed warnings. | Joel Sherrill | 2000-01-04 | 1 | -1/+1 |
* | + Updated copyright information. | Jennifer Averett | 1999-11-17 | 1 | -0/+3 |
* | Combination of committing some new files which had been overlooked | Joel Sherrill | 1999-11-10 | 1 | -0/+59 |
and adding code which installed screens for itron tests. |
