* itronhello/.cvsignore: Remove.
* itronhello/Makefile.am: Remove.
* itronhello/init.c: Remove.
* itronhello/itronhello.doc: Remove.
* itronhello/itronhello.scn: Remove.
* itronhello/system.h: Remove.
* .cvsignore: Remove.
* ChangeLog: Remove.
* Makefile.am: Remove.
* README: Remove.
* configure.ac: Remove.
* itrontests.am: Remove.
* itronmbf01/.cvsignore: Remove.
* itronmbf01/Makefile.am: Remove.
* itronmbf01/init.c: Remove.
* itronmbf01/itronmbf01.doc: Remove.
* itronmbf01/itronmbf01.scn: Remove.
* itronmbf01/system.h: Remove.
* itronmbox01/.cvsignore: Remove.
* itronmbox01/Makefile.am: Remove.
* itronmbox01/init.c: Remove.
* itronmbox01/itronmbox01.doc: Remove.
* itronmbox01/itronmbox01.scn: Remove.
* itronmbox01/system.h: Remove.
* itronsem01/.cvsignore: Remove.
* itronsem01/Makefile.am: Remove.
* itronsem01/init.c: Remove.
* itronsem01/itronsem01.doc: Remove.
* itronsem01/itronsem01.scn: Remove.
* itronsem01/system.h: Remove.
* itrontask01/.cvsignore: Remove.
* itrontask01/Makefile.am: Remove.
* itrontask01/init.c: Remove.
* itrontask01/itrontask01.doc: Remove.
* itrontask01/itrontask01.scn: Remove.
* itrontask01/system.h: Remove.
* itrontask01/task1.c: Remove.
* itrontask02/.cvsignore: Remove.
* itrontask02/Makefile.am: Remove.
* itrontask02/dormant.c: Remove.
* itrontask02/init.c: Remove.
* itrontask02/itrontask02.doc: Remove.
* itrontask02/itrontask02.scn: Remove.
* itrontask02/system.h: Remove.
* itrontask03/.cvsignore: Remove.
* itrontask03/Makefile.am: Remove.
* itrontask03/init.c: Remove.
* itrontask03/itrontask03.doc: Remove.
* itrontask03/itrontask03.scn: Remove.
* itrontask03/preempt.c: Remove.
* itrontask03/system.h: Remove.
* itrontask03/task1.c: Remove.
* itrontask03/task2.c: Remove.
* itrontask03/task3.c: Remove.
* itrontask04/.cvsignore: Remove.
* itrontask04/Makefile.am: Remove.
* itrontask04/init.c: Remove.
* itrontask04/itrontask04.doc: Remove.
* itrontask04/itrontask04.scn: Remove.
* itrontask04/system.h: Remove.
* itrontask04/task1.c: Remove.
* itrontask04/task2.c: Remove.
* itrontask04/task3.c: Remove.
* itrontime01/.cvsignore: Remove.
* itrontime01/Makefile.am: Remove.
* itrontime01/init.c: Remove.
* itrontime01/itrontime01.doc: Remove.
* itrontime01/itrontime01.scn: Remove.
* itrontime01/system.h: Remove.
* itronhello/init.c, itronhello/itronhello.doc, itronhello/system.h,
itronmbf01/init.c, itronmbf01/itronmbf01.doc, itronmbf01/system.h,
itronmbox01/init.c, itronmbox01/system.h, itronsem01/init.c,
itronsem01/itronsem01.doc, itronsem01/system.h, itrontask01/init.c,
itrontask01/itrontask01.doc, itrontask01/system.h,
itrontask01/task1.c, itrontask02/dormant.c, itrontask02/init.c,
itrontask02/itrontask02.doc, itrontask02/system.h,
itrontask03/init.c, itrontask03/itrontask03.doc,
itrontask03/preempt.c, itrontask03/system.h, itrontask03/task1.c,
itrontask03/task2.c, itrontask03/task3.c, itrontask04/init.c,
itrontask04/itrontask04.doc, itrontask04/system.h,
itrontask04/task1.c, itrontask04/task2.c, itrontask04/task3.c,
itrontime01/init.c, itrontime01/system.h: URL for license changed.
itronhello/Makefile.am: Reflect having moved automake.
itronmbf01/Makefile.am: Reflect having moved automake.
itronmbox01/Makefile.am: Reflect having moved automake.
itronsem01/Makefile.am: Reflect having moved automake.
itrontask01/Makefile.am: Reflect having moved automake.
itrontask02/Makefile.am: Reflect having moved automake.
itrontask03/Makefile.am: Reflect having moved automake.
itrontask04/Makefile.am: Reflect having moved automake.
itrontime01/Makefile.am: Reflect having moved automake.
* itronhello/Makefile.am: Use .$(OBJEXT) instead of .o.
* itronmbf01/Makefile.am: Use .$(OBJEXT) instead of .o.
* itronmbox01/Makefile.am: Use .$(OBJEXT) instead of .o.
* itronsem01/Makefile.am: Use .$(OBJEXT) instead of .o.
* itrontask01/Makefile.am: Use .$(OBJEXT) instead of .o.
* itrontask02/Makefile.am: Use .$(OBJEXT) instead of .o.
* itrontask03/Makefile.am: Use .$(OBJEXT) instead of .o.
* itrontask04/Makefile.am: Use .$(OBJEXT) instead of .o.
* itrontime01/Makefile.am: Use .$(OBJEXT) instead of .o.
enable this support.
* itronhello/init.c, itronmbf01/init.c, itronmbox01/init.c,
itronsem01/init.c, itrontask01/task1.c, itrontask02/init.c,
itrontask03/task1.c, itrontask04/task3.c, itrontime01/init.c: Modified.
* itronhello/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itronmbf01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itronmbox01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itronsem01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontask01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontask02/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontask03/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontask04/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontime01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontask03/Makefile.am: include leaf.am instead of leaf.cfg.
* itrontask04/Makefile.am: include leaf.am instead of leaf.cfg.
* itronmbf01/Makefile.am: include leaf.am instead of leaf.cfg.
* itronsem01/Makefile.am: include leaf.am instead of leaf.cfg.
* itronhello/Makefile.am: include leaf.am instead of leaf.cfg.
* itrontime01/Makefile.am: include leaf.am instead of leaf.cfg.
* itrontask01/Makefile.am: include leaf.am instead of leaf.cfg.
* itrontask02/Makefile.am: include leaf.am instead of leaf.cfg.
* itronmbox01/Makefile.am: include leaf.am instead of leaf.cfg.
* itrontask01/system.h: Configure enough stack memory.
* itronhello/Makefile.am, itronmbf01/Makefile.am,
itronmbox01/Makefile.am, itronsem01/Makefile.am,
itrontask01/Makefile.am, itrontask02/Makefile.am,
itrontask03/Makefile.am, itrontask04/Makefile.am,
itrontime01/Makefile.am: Include compile.am
<corsepiu@faw.uni-ulm.de> which converted fiels to automake.
Addtional major bugs:
critical.
Increased stack space.
prints a message instead of actually testing since the message buffer
implementation is not in yet.
and adding code which installed screens for itron tests.
for RTEMS.
