path: root/c/src/tests/.cvsignore (follow)
* 2003-11-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-111-14/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * aclocal/canonical-target-name.m4: Remove. * aclocal/canonicalize-tools.m4: Remove. * aclocal/check-custom-bsp.m4: Remove. * aclocal/check-cxx.m4: Remove. * aclocal/check-itron.m4: Remove. * aclocal/check-multiprocessing.m4: Remove. * aclocal/check-networking.m4: Remove. * aclocal/check-posix.m4: Remove. * aclocal/check-tests.m4: Remove. * aclocal/check-tool.m4: Remove. * aclocal/config-subdirs.m4: Remove. * aclocal/enable-bare.m4: Remove. * aclocal/enable-cxx.m4: Remove. * aclocal/enable-itron.m4: Remove. * aclocal/enable-multiprocessing.m4: Remove. * aclocal/enable-networking.m4: Remove. * aclocal/enable-posix.m4: Remove. * aclocal/enable-rtemsbsp.m4: Remove. * aclocal/enable-tests.m4: Remove. * aclocal/env-rtemsbsp.m4: Remove. * aclocal/gcc-isystem.m4: Remove. * aclocal/gcc-pipe.m4: Remove. * aclocal/gcc-specs.m4: Remove. * aclocal/multilib.m4: Remove. * aclocal/path-ksh.m4: Remove. * aclocal/prog-cc.m4: Remove. * aclocal/prog-cxx.m4: Remove. * aclocal/project-root.m4: Remove. * aclocal/quoting.m4: Remove. * aclocal/rtems-cpu-subdirs.m4: Remove. * aclocal/rtems-flags.m4: Remove. * aclocal/rtems-test-no-pause.m4: Remove. * aclocal/rtems-top.m4: Remove. * aclocal/target.m4: Remove. * aclocal/tool-paths.m4: Remove. * aclocal/version.m4: Remove. * .cvsignore: Remove. * ChangeLog: Remove. * Makefile.am: Remove. * PROBLEMS: Remove. * README: Remove. * configure.ac: Remove. * automake/compile.am: Remove. * automake/host.am: Remove. * automake/leaf.am: Remove. * automake/local.am: Remove. * automake/subdirs.am: Remove.
* 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-211-3/+3
| | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-111-0/+1
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-131-0/+13
