* bsp.mak: Remove support for profile-variant.
* configure.ac: Ditto.
* directory.cfg: Ditto.
* compilers/gcc-target-default.cfg: Ditto.
* make/README: Remove references to profile-variant.
* target.cfg.in: New, copy of c/make/target.cfg.in.
* configure.ac: Add target.cfg.
* Makefile.am: Add target.cfg.
* configure.ac: Only symlink leaf.cfg.
* configure.ac: Remove references to Templates.
Use local AC_CONFIG_LINKS.
* README: Relocated from make/
* lib.cfg: Ditto.
* configure.ac: Unconditionally check for CXX (Hack to bug in
autoconf > 2.54).
* configure.ac: Remove RTEMS_BSP_ALIAS.
Add RTEMS_CHECK_BSP_CACHE.
* Makefile.am: Remove RTEMS_BSP.cache generation.
Remove handling custom/*.cfgs.
Remove handling custom/default.cfg.
* configure.ac: Remove handling of custom/*.cfgs.
Remove auto* generated custom/default.cfg.
* custom/Makefile.am: Remove.
* compilers/Makefile.am: Remove.
* compilers/.cvsignore: Remove.
* Makefile.am: Merge-in former */Makefile.ams.
Add more vars to <BSP>.cache.
* configure.ac: Reflect changes above. Cosmetic fixes.
* compilers/Makefile.am: Remove AUTOMAKE_OPTIONS.
* custom/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.in: Remove.
