This is old and there are better design patterns for threading and C++.
We recommend you use the new C++ standards based support.
Closes #2777.
* include/rtems++/rtemsEvent.h, include/rtems++/rtemsMessageQueue.h:
Fixed timeout calculation.
* include/rtems++/rtemsEvent.h, include/rtems++/rtemsMessageQueue.h,
include/rtems++/rtemsSemaphore.h, include/rtems++/rtemsTimer.h,
src/rtemsTask.cc: Eliminate all public use of TOD conversion
routines.
include/rtems++/rtemsSemaphore.h, src/rtemsTask.cc: Use public API
not _TOD_Microseconds_per_tick.
* librtems++/include/rtems++/rtemsEvent.h,
librtems++/include/rtems++/rtemsMessageQueue.h,
librtems++/include/rtems++/rtemsSemaphore.h,
librtems++/include/rtems++/rtemsTask.h, librtems++/src/rtemsEvent.cc,
librtems++/src/rtemsMessageQueue.cc,
librtems++/src/rtemsSemaphore.cc, librtems++/src/rtemsTask.cc: Change
rtems_unsigned32 to uint32_t.
* include/rtems++/rtemsEvent.h, include/rtems++/rtemsInterrupt.h,
include/rtems++/rtemsSemaphore.h, include/rtems++/rtemsStatusCode.h,
include/rtems++/rtemsTask.h, include/rtems++/rtemsTaskMode.h,
include/rtems++/rtemsTimer.h, src/rtemsEvent.cc,
src/rtemsInterrupt.cc, src/rtemsMessageQueue.cc,
src/rtemsSemaphore.cc, src/rtemsStatusCode.cc, src/rtemsTask.cc,
src/rtemsTimer.cc: URL for license changed.
