* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am: Remove build-variant support.
* Makefile.am: Cosmetics.
* Makefile.am: Preinstall dirs.
* Makefile.am: Don't include lib.am.
* configure.ac: Add subdir-objects to AUTOMAKE_OPTIONS
* Makefile.am: Use automake-compilation rules.
* Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Add dirstamp support.
* Makefile.am: Remove all-local: $(ARCH).
* Makefile.am: Eliminate *_O_FILES.
Use install-data-local instead of bsplist_DATA.
* configure.ac: Require autoconf-2.57/automake-1.7.2.
Apply 4th arg to AC_INIT to prevent autoconf to corrupt package name.
* src/Makefile.am: Remove.
* Makefile.am: Merge-in src/Makefile.am, include/Makefile.am.
Unconditionally check for CXX.
* include/rtems++/Makefile.am: Remove.
